How to remove driver side window switch
Flynn
Post by Flynn » Wed Nov 01, 2017 4:28 pm
How do I remove the driver side window switch from my 1 series E87 without causing damage to the cluster or surrounding
Re: How to remove driver side window switch
Post by Nottsknots » Wed Nov 01, 2017 6:10 pm
Easy:
https://www.newtis.info/tisv2/a/en/e87- ... or/HvViigI
Its best with trim removal tools, but I found a wide flat screwdriver was Ok - just be very careful not to dent or scratch the plastic.
I also found it easier to start from the back clips - the three at the front are much easier once the back two are released.
Flynn
Post by Flynn » Wed Nov 01, 2017 7:05 pm
That is fantastic info, I will give it a go, many thanks
Return to “How To's”
