Rear right tyre rubbing on arch
jordanlord93
Post by jordanlord93 » Mon Jun 19, 2017 10:13 am
Morning,
I've had this issue for the last 18 months or so and it's really starting to wear thin (just like my tyre!!). Whenever I have someone in the back or go down a dip in the road the wheel arch rubs on the back right tyre - I have recently had brand new shocks and springs put on the car and it's still doing it - the arch is rubbing on the outer right edge of the wheel only.
I had the car jacked up yesterday and had a bit of a play and could not see/feel anything wrong the suspension mechanics but at the end of the day I'm no mechanic and do I really know what I'm looking for :roll: I just don't get it's the right hand side only :censored:
Is this is a known issue or does anyone have any idea what it could be? Anything will be appreciated !! Thanks :)
Jordan
First BMW - 57plate 118d M Sport - Alpine White - Xenon Lights - Darkline rear lights - LED number plate bulbs - Auto wipers and lights - 208m Alloys
Re: Rear right tyre rubbing on arch
Post by marco_polo » Mon Jun 19, 2017 10:31 am
What do your bump stops look like, still in good condition?
blythe92
Post by blythe92 » Mon Jun 19, 2017 10:46 am
Chances are you just need to roll the arch lip that sticks out inside the arch of the wheel . Roll that so it's flat against the arch and that should solve your problem, either that or the camber has slightly come out of alignment when changing suspension.
BMW 135i N54-Decat downpipes from vrsf - intercooler from rad tec - MHD Stage 2+-forge diverter valves - 550i clutch - Eibach springs - Quaife diff - Ferodo ds2500 pads - Carbon Rear diffuser and spoiler - M3 LCA's.
Post by marco_polo » Mon Jun 19, 2017 10:53 am
Shouldn't need an arch roll with standard 208m's, unless you're running spacers too? In which case, remove your spacers!
Toed64
Post by Toed64 » Mon Jun 19, 2017 11:03 am
Mine did that after a snowy drive - something these cars don't do well! One of my arch liners had moved and was misaligned above the o/s rear tyre. A bit of pushing and squeezing put it back. Problem solved.
What size tyres are you running?
2008 E81 130i replacing my 2010 E82 N55 135i that's for sale...
jordanlord93
Post by jordanlord93 » Mon Jun 19, 2017 11:08 am
I'll double check the arch and see if I can roll it then - thanks !! Also, no spacers on, I'll update you all :)
Toed64
Post by Toed64 » Mon Jun 19, 2017 12:33 pm
If you have standard wheels, something is not right. As Marco says, you shouldn't need to roll the arches unless you are using big tyres/wheels. Even though my car has 255/35/18 tyres on the OE wheels, the arch clearance is close, but the tyres never rub.
As Blythe92 suggested, perhaps your rear alignment needs setting up.
