:? Hi to you all, ongoing issue with my 116 petrol. 59 plate
Symptoms
• only happens when first started (or cold?)
Once I start there are engine vibrations and you can see a lot of it on the gearstick. The car is also juddery in acceleration for the first few mins, once the car is warm it sort of goes away.
It's an intermittent problem where I'll get it back for a couple of days then it'll go away for a week or two then come back and the vibration is quite heavy however after driving it for a while it does always either go away or get a lot better.
Any ideas? Happened this morning just when about to do a long drive to London not ideal!
Any help or questions would be appreciated
Cheers all
Symptoms
Cheers all
