Runflats rear front non runflats
ukmonkey
Post by ukmonkey » Mon Sep 25, 2017 6:29 pm
Got 2 new conti runflats on the rear but front are due to be changed. Will it affect the car if I replace front with non runflats ? Anyone done this ? Will change the rear once they have worn out.
2010 Space Gray 120d m sport
Re: Runflats rear front non runflats
Post by marco_polo » Mon Sep 25, 2017 6:34 pm
If you have to mix tyre types (and your insurance company is happy for you to do so), the way around you're proposing is the safest. It's when people fit proper tyres on the back and Runcraps on the front, that the car becomes unstable.
Trojantrow
Post by Trojantrow » Mon Sep 25, 2017 6:36 pm
I've not done it myself yet. But to be honest, it's common knowledge on here that it will affect it. But Its how much it affects it that matters. For instance. Buying 94 extra load tyres and running the fronts at a higher psi to compensate and get the balance right. And not driving like a b*** end will help.. If you drive fast all the time then it will affect it more I would say. But someone is about to give you a proper answer I would imagine.
ukmonkey
Post by ukmonkey » Mon Sep 25, 2017 6:37 pm
Good point never thought about the insurance!
Trojantrow
Post by Trojantrow » Tue Sep 26, 2017 2:05 pm
Im no expert but I heard that insurance doesn't have anything to do with run flat vs non run flat tyres. I thought it was all about having the correct sizes,load rating and speed rating. If this could be confirmed that would be great as I'm doing this very soon. Not questioning you Marco as you know alot more than me. Just would be nice to know.
Post by marco_polo » Tue Sep 26, 2017 2:45 pm
It seems to vary from company to company. I've been refused insurance in the past for swapping to (the correct size and rating) winter tyres in the winter, to make my car less likely to be in an accident! Other companies have said they literally couldn't give a flying feck, as long as they have at least 1.6mm of tread on 3/4 of the tyre!!
Check with your company, don't take anything for granted, especially if you're getting advice from some random douche-bag on the internet.
michaele82
Post by michaele82 » Wed Sep 27, 2017 1:43 pm
What about those of you who have gone for the slightly wider tyres when going from runflats to normal, have you told your insurance about the size change? If so did it affect your premium?
Post by marco_polo » Wed Sep 27, 2017 3:34 pm
Always check with your insurance company before making any and all modifications from standard spec.
