I looking at changing the engine oil in my car in the next week or two but I've got a couple of questions before I do.
On my old cars I would suck the engine oil out using an oil vacuum extractor as it would save removing the under tray and rolling around on the floor, How do people remove the oil in their cars, do you use the drain plug or oil vacuum extractor ?
Which oil would you recommend for a 120D (177bhp) ? Halfords is coming up with Castrol Edge 0W/30 or their own brand and PETRONAS oil 5W/30 ?
I'm happy to not go with longer life oil as I'm not a fan of oil being used for 20k miles, I would rather change the oil at 10/12k miles, Any advice would be welcome.
When I do my oil change (N47) its ramps as sump drain plug out. Dont trust an extractor to get all the oil out. TBH even after 1 hour there are still drips of oil. I use Castrol 0w30 but may consider 5w30 to be honest I dont think the brand matters as long as it LL04. Max 7k between changes though.
And Petronas seems to be fine - I have been using it for a few years now as you can usually get it cheap from ECP when they do an oil code, mind you im sure Halfords own brand would be ok if its LL04
If oil was oil, then surely when using any brand of oil within the same engine in the same car covering the same millage, you would expect the same oil usage??
45K members
