Vibration after Engine change on 2008 123d
Crab Fiddler
Post by Crab Fiddler » Sat Jan 20, 2018 10:00 am
Hi Everyone,
I’ve just had to change engines in my 2008 123d after the dreaded Cam Chain decided to have a day off, after 140k of working.
I managed to get a replacement engine and also had fitted a new clutch and Dual Mass Flywheel.
I took it for a test drive and when accelerating in 2nd and 3rd gear (20-30mph) there is a high frequency vibration that feels like the prop shaft. After 40mph the the vibration goes and is replaced by low frequency hum. After 45mph that seems to go and the car runs relatively smooth.
Any of you BMW boffs out there have an idea of what the vibration is caused by?
Cheers,
Re: Vibration after Engine change on 2008 123d
Post by marco_polo » Sat Jan 20, 2018 11:20 am
Bad luck on the chain snap, they all go sooner or later. :(
If your vibration is road speed related (rather than rev's related) we can pretty much rule out the engine. So that leaves us with everything from the gearbox back, giubo, prop, diff, driveshafts, brakes, and wheel/tyre balance. I'd start with the giubo-doughnut.
Ktmpedro220
Post by Ktmpedro220 » Sat Jan 20, 2018 11:44 am
Nightmare about the engine. Hope you get this sorted soon!
David 8
Post by David 8 » Sat Jan 20, 2018 12:40 pm
Can't help with your issue sorry, a little OT here but did you ever have the recall done or the tensioner thingy changed ?
2009 White E81 123D, Factory Xenon's, I-Drive 313's
Crab Fiddler
Post by Crab Fiddler » Sun Jan 21, 2018 11:34 am
Thanks for the suggestions and the condolences. I will get on the case next week and I will post with what I find.
Mike_RS
Post by Mike_RS » Sun Jan 21, 2018 10:01 pm
I had a new engine in my 135i after just 40k so you've done better than me! Haha
When I got the car back I was having vibrations coming through the steering wheel at slow speeds and this also happened when I turned left and give it some throttle. I took it back to BMW and they found a heat shield that sits on front of the steering rack had been bent when they lowered the engine in.. a slight adjustment to the shield seems to have sorted mine.. although I do still get a very slight vibration when cornering at high speed so I'm going to have another look at this myself when it eventually stops raining, as it may need a further adjustment.
Black sapphire metallic - E82 135i N55 - BMWP Exhaust - Suspension - Brakes - Carbon Mirrors - 18" 313 wheels with PS4's - Wagner Downpipe - Wagner Intercooler - LED Darklines
Crab Fiddler
Post by Crab Fiddler » Tue Jan 23, 2018 9:24 pm
Thanks for the info. Most definitely food for thought.
Good luck with the continued vibration.
My118d
Post by My118d » Sun Jan 28, 2018 1:10 am
This can happen at times with engine replacements. First I would back out all the bolts from sub frame to engine mounts. Back them out about 5mm each. Put the car back on the ground and give the engine a bunch of good revs in neutral. Re tighten mount bolts to spec.
Go for a test drive.
If still a vibration un bolt drive shaft from gear box end a rotate drive shaft 180 degrees.
Crab Fiddler
Post by Crab Fiddler » Sat Feb 03, 2018 6:26 am
Vibration sorted guys! It was indeed the Giubo-Doughnuts. She now drives amazing with the new engine, next thing on the lists is to give her a few more herbs :D
Thanks again for all the help!
Post by marco_polo » Sat Feb 03, 2018 8:51 am
Good work. :)
Mike_RS
Post by Mike_RS » Sat Feb 03, 2018 5:36 pm
What did you do exactly to resolve it?
Post by marco_polo » Sat Feb 03, 2018 5:57 pm
Swapped the old knackered giubo doughnut for a new, non-knackered one, I assume.
Mike_RS
Post by Mike_RS » Mon Feb 05, 2018 5:27 pm
Was their any signs of excessive wear on the Guibo when you removed it? Did you replace the bolts for new items too?
Interested to know as mine may be knackered too.
Post by marco_polo » Mon Feb 05, 2018 5:32 pm
You sometimes see surface cracks, or even full failure:
Ktmpedro220
Post by Ktmpedro220 » Wed Feb 21, 2018 3:51 pm
Glad it's sorted!
