Winston1192 said:
Any more info on what you have had done pal 👍
DEPO V2 split with the following modifications:
- Upgraded Dipped Beam Morimoto H1 (I believe) BiXenon Projectors with Morimoto HID Kit. I was going to go for D2S Projectors but couldn't justify the extra cost.
- Dummy High Beam Projector.
- Morimoto XBT-RGB RGB Rings (Inner & Outer).
- Morimoto XBT-RGB RGB Quad Demon Eyes (Inner & Outer).
- Morimoto XBT Bluetooth Controller to control the Rings/Demon Eyes.
- Modified indicator bulb holders for Morimoto LED Indicators.
- Morimoto Hi/Lo control file for the BiXenon projectors.
- Custom projector brackets.
- Sealed with Morimoto RetroRubber.
Built by one of the best in the country (EM Tuning) using some of the best parts (Morimoto).
They cost a pretty penny, incidentally, they will be up for sale within a month or so, so if you're interested, PM me.
You can see the RGB portions in action here, in the videos section:
https://www.facebook.com/EM-Tuning-1151784784860017/. I have more videos on my Instagram. They are truly one of a kind and I was the FIRST in the UK to have a COMPLETE Morimoto build on a 1 Series, I may be the only one.
Twenny said:
Yeah true, maybe ball ache isn't what I meant, but it comes with a serious price tag mate that's for sure to do what you've done.
Price tag varies depending on what you go for. You don't have to go down the route I did and have the cost that I had, although EM Tuning did me a SMASHING deal and I had to pay a little bit more to have the brackets designed and made, the next person to have projectors upgraded in E8x DEPOs will save here.
You can do Morimoto XSB rings and leave the switchback wires disconnected if you just wanted white rings. You don't need the demon eyes but if you did then you don't need the controller as you can get away with just connecting the red/black wires if you wanted red demons or blue/black if you wanted blue or green/black if you wanted green. The RGB stuff is purely personal choice. The only reason I did it, is because I wanted to be different to the norm and I think it's pretty cool. I cannot fault EM Tuning in any way, his work is second to none, his customer service is amazing and the parts he uses are great quality.
I've had lights made by two other builders and I wish I didn't. Both of them were cowboys and I wouldn't recommend if they were the last people on the planet.
