Finally done my diff oil change
Justchris17
Post by Justchris17 » Thu Mar 08, 2018 7:49 pm
I done my diff oil today such a straight forward job and couldn't believe how dirty the oil was it was jet black no way this is a lifetime oil! I only got 690ml sucked out roughly. I fitted my new dimple diff plug I was planning on changing it again tomorrow when the new oil mixes with the old stuff I couldn't get out is this overkill?ImageImageImageImageImageImageImageImageImageImage
Black 2010 135i n55
Fritz
Post by Fritz » Thu Mar 08, 2018 8:27 pm
Good job! Got a few questions for you- Whats the capacity of the diff? Where's the fill plug btw and how come you also used a replacement plug, are they one use?
Justchris17
Re: Finally done my diff oil change
Post by Justchris17 » Thu Mar 08, 2018 8:41 pm
Hi mate I've been told the capacity is approx 1-1.2l and that is the fill plug in the pics, these don't have a drain plug because it's meant to be lifetime oil so you have to remove the refill plug and suck as much old fluid as you can hence the oil suction gun. The new blue plug I put in is a Dimple magnetic plug that I fitted instead of the standard plug I think it's a good idea to have on as there is nothing to filter the oil so a magnet to attract any swarf will be great in my eyes and lots of other people agree.
I got about 690ml that I injected into the bottle but I would guess I got closer to 700ml as there was some oil I couldn't get out the pump.
Black 2010 135i n55
Fritz
Post by Fritz » Thu Mar 08, 2018 8:50 pm
I see, I did wonder as I was having a good look around the diff and couldn't see another plug. Are you sure you managed to move the pipe around enough to get to the lowest part for the diff? Was it also sat on level ground for a while before you did the job? If capacity is 1.2 then 700ml is not great
Yup agree the plug is worth having, how much was it?
Justchris17
Post by Justchris17 » Thu Mar 08, 2018 9:35 pm
Yeah it was level ground and moved pipe as much as I could and tried bending ect but couldn't get anymore pipe wasn't getting far enough. I read somewhere someone taped some wire to the hose to keep it in a U bend to reach bottom I might try that next time
Black 2010 135i n55
Justchris17
Post by Justchris17 » Thu Mar 08, 2018 9:37 pm
Plug was £19.99 with 2 washers.
https://oppositelock.kinja.com/simply-s ... 1724511544
The diy on here the guy only managed 0.5l
Black 2010 135i n55
Justchris17
Post by Justchris17 » Thu Mar 08, 2018 9:43 pm
Marco if you read this do you think I got enough new oil in or should I try do it again?
Black 2010 135i n55
YLS
Post by YLS » Thu Mar 08, 2018 10:59 pm
Did mine last week with the same sucky pump and got out around 900ml. As long as it's full now with the correct oil it should be fine though.
Justchris17
Post by Justchris17 » Fri Mar 09, 2018 1:21 am
Doesn't matter what I done it wouldn't suck any more up :x it should be more than enough it's defo better than it was
Black 2010 135i n55
Justchris17
Post by Justchris17 » Fri Mar 09, 2018 1:21 pm
Ok I done it again just now and got 1 litre out well pleased haha! I taped a coat hanger to the hose to make it rigid to keep shape to get to the bottom of the diff. The magnetic plug picked up some filings over night which are a pain the get off the plug cause they are magnetised lol. ImageImageImageImageImageImageImage
Black 2010 135i n55
Mike_RS
Post by Mike_RS » Fri Mar 09, 2018 3:25 pm
Good effort Chris, I'm doing mine sometime over the next week.. some useful tips in here! :)
Black sapphire metallic - E82 N55 135i - BMWP Exhaust - Suspension - Brakes - Carbon Mirrors- 18" 313 wheels with PS4's - Wagner DP - LED Darklines
Justchris17
Post by Justchris17 » Fri Mar 09, 2018 5:30 pm
Cheers mike and good luck I used a coat hanger but I recommend anything that will help keep the pipe rigid. I think I might do mine every year or 2 years now
Black 2010 135i n55
Fritz
Post by Fritz » Wed Mar 14, 2018 12:43 am
Nice going getting the last bit out again, was worth it after all!
Where did you get the diff plug by the way?
Justchris17
Post by Justchris17 » Wed Mar 14, 2018 6:49 pm
Yeah defo pal and il dig up the link for the plug
Black 2010 135i n55
Justchris17
Post by Justchris17 » Wed Mar 14, 2018 6:51 pm
https://shop.motorsport-developments.co ... -350-p.asp
Black 2010 135i n55
