E82 135i low profile long reach jack
Justchris17
Post by Justchris17 » Mon Mar 12, 2018 9:37 pm
Tried searching but seems to be a lot of confusion and most I saw tend to jack one corner at a time..
The front central jacking point on these at the front is quite far back and I don't think a normal jack will reach which jack has people bought that reach this jacking point with no issues and don't cost a arm and a leg?
Black 2010 135i n55
Mike_RS
Re: E82 135i low profile long reach jack
Post by Mike_RS » Tue Mar 13, 2018 6:03 am
I just drive the car onto two wooden blocks to increase the clearance for the Jack. I have a Sealey Aluminium race Jack which fits under fine.
Black sapphire metallic - E82 N55 135i - BMWP Exhaust - Suspension - Brakes - Carbon Mirrors- 18" 313 wheels with PS4's - Wagner DP - LED Darklines
Rustle
Post by Rustle » Sun Mar 18, 2018 6:06 pm
Mike_RS wrote:I just drive the car onto two wooden blocks to increase the clearance for the Jack. I have a Sealey Aluminium race Jack which fits under fine.
I got some 3 tonne caravan levelling ramps from Amazon and drive onto those then jack up. Nice and light and come in a little carry bag.
E87 '05 130i; BMWP Brakes, intake, & exhaust. birds arb's, quaife, meister R coilovers, m3 lca, goodridge lines, oz Ultraleggera and 595 RSR's.
Fritz
Post by Fritz » Sun Mar 18, 2018 6:30 pm
I have an sgs engineering low profile jack, cost about £100 delivered. Well made bit of kit but I still need to drive onto two blocks of wood to clear the msport bumper
Fritz
Post by Fritz » Sun Mar 18, 2018 6:32 pm
I just so happening to be doing an oil change right now, these are said bits of wood
Justchris17
Post by Justchris17 » Tue Mar 20, 2018 9:18 am
Cheers lads. Does anyone use them rubber pad inserts for the side jacking points aswell?
Black 2010 135i n55
MPN1
Post by MPN1 » Tue Mar 20, 2018 11:39 am
I have one of those pads but they only work if your jacking point cover is in good condition, not chewed up or crushed by other jacks.
2007 130i le m sport. Bilstein B6 Rears with Powerflex Mounts. Camber Pin Mod. BMWP Grilles. Royal Steering Wheel.
