Tyre seal issue - slow pressure loss
mikeyscott
Post by mikeyscott » Wed Mar 14, 2018 6:18 pm
Got a from tyre that regularly losses air, had it checked and tyre is fine, but corrosion or something on the wheel. Anyone else this, never had this on any other car?
Solution, refirb / replace wheel?
Don’t drive the 135i much atm. Prob 100 miles per month as daily Volvo C30.
135i E82 2011 AW, Birds B1 Dynamics Package, MPSS
Volvo C30 D4 R - Daily
VW Golf MK5 R32 09 - Gone and miss the traction.
123d E87 59 - Gone and hated it
Volvo S40 T5 Polestar 08 - Gone - Missed as mega comfortable
Seat Leon Cupra 03 - Gone
Re: Tyre seal issue - slow pressure loss
Post by Nottsknots » Wed Mar 14, 2018 6:44 pm
Who said it was the wheel?
Most likely cause would be the valve; my local place would change one for a fiver. Migt be a cracked or distorted alloy, but I wouldnt do anything unless I was certain it wasnt the valve first.
mikeyscott
Post by mikeyscott » Wed Mar 14, 2018 6:46 pm
Local tyre place.
Planning on getting down to Protyre at the weekend to get it all checked.
Cars all due a 4 wheel alignment
Tin
Post by Tin » Wed Mar 14, 2018 9:37 pm
Has the wheel been placed in a tub of water to check for air bubbles around the alloy edge, with the cold weather the tyre bead can break and cause the tiniest air leak. Could be a case of just deflating the tyre, breaking the bead, rotating the tyre, and re-applying the bead and inflating.
Certified Mod junkee :D
0l0dom0l0
Post by 0l0dom0l0 » Wed Mar 14, 2018 10:49 pm
Just get the tyre taken off, clean the head on the tyre and rim, 're seat and fit new valve.
Should be £10 at a garage. £15 at most.
B12 KIT with M3 LCA and TS.
Jfk
Post by Jfk » Thu Mar 15, 2018 9:46 am
I thought it was just me that had this problem ! I have had three very very slow air leaks over the year I have owned my 135i ..one was a leaking valve , another was an old puncture repair that was still leaking and the third was a very very tiny air leak that only just released the tiniest of bubbles underwater.
I have just bought a plasterers mixing trough off Amazon to dunk wheels in to find these elusive leaks.
2010 135 i Coupe in Black
