E87 Window frame cover replacement
jay100
Post by jay100 » Thu Mar 29, 2018 4:11 pm
Hi all, Picked up a 2011 E87 1 Series with some damage to the window frame cover on the rear door - picture below. Been looking for a DIY guide to replace but no luck - Is this something that can be done without too much trouble? If so anyone know where I can find a guide? Cheers in advance.
ANTA
Re: E87 Window frame cover replacement
Post by ANTA » Thu Mar 29, 2018 4:48 pm
jay100 wrote:Hi all, Picked up a 2011 E87 1 Series with some damage to the window frame cover on the rear door - picture below. Been looking for a DIY guide to replace but no luck - Is this something that can be done without too much trouble? If so anyone know where I can find a guide? Cheers in advance.
Hi you get a replacement part if you look on YouTube somebody has done this I've done it on my E46 you do it
Sent from my SM-G900F using Tapatalk
jay100
Post by jay100 » Thu Mar 29, 2018 4:58 pm
Nice one thanks, any idea the youtube link? Sure i cam across something similar before when i wasn't looking but can't seem to find it now that i am! Typical.
Post by marco_polo » Thu Mar 29, 2018 5:00 pm
B Pillar trims can be replaced, but it's a pain of a job.
riccie_120i
Post by riccie_120i » Thu Mar 29, 2018 5:03 pm
Hi
I did this repair to my car. It was the rear/passenger, but I think the principles are the same. There are some guides available. I will try and dig out, but essentially you will find it is just a few torx screws to release it and refit.
riccie_120i
Post by riccie_120i » Thu Mar 29, 2018 5:08 pm
front
https://www.newtis.info/tisv2/a/en/e87- ... nt/EVL5WGs
rear door
https://www.newtis.info/tisv2/a/en/e87- ... ar/EL6GlgW
I thought it was a piece of preverbial, took about an hour all in.
voila!
* (should caveat, these are the instructions I followed for my particular car, so may be an approximation but you can hopefully find the equivalent instructons or use this is a basis to explore further)
jay100
Post by jay100 » Thu Mar 29, 2018 5:30 pm
Thanks guys for such a swift response - will take a look!
