Clutch Judder Solved!!
flyboy777
Post by flyboy777 » Sat Jan 14, 2012 7:27 pm
My 2007 123D has only done 30,000 careful miles and just lately the infamous clutch judder was getting worse.
It was only happening when cold when pulling away from a standstill.
There is a nasty uphill junction v close to my house and it was getting v bad here.
I am v careful with the car and try not to slip the clutch v much, I wondered if maybe there was a buildup of crap on the flywheel/clutch plate so I floored it in 5th at about 40-50 mph and gently depressed the clutch and held it when it was slipping a little for about 5 seconds then repeated it a minute or 2 later.
Probably taken a couple of thousand miles of the life but this morning from cold I had no judder for the first time in weeks so hopefully its done the trick.
Cant condone everyone trying this but it was getting so bad I had to try something, if you do try it dont let the engine rev too high or you may burn/scorch the clutchplate wont do any good, just let it rev 500-1000 rpm above where it should be. Its probably no worse for the clutch than when an elderly person parks their Micra in tescos you know all revs and clutch slip!
2017 M2.
2015 F31 320D.
2007 123D. P-Torque remap.
Locoblade
Re: Clutch Judder Solved!!
Post by Locoblade » Sun Jan 15, 2012 1:53 pm
Glad Im not the only one who's found that
http://www.babybmw.net/viewtopic.php?f= ... &start=744" onclick="window.open(this.href);return false;
Its not a cure though, just a temporary reprieve, mine comes back within a few days :(
flyboy777
Post by flyboy777 » Tue Jan 17, 2012 3:51 pm
I'll report back on how it goes,
3 days judder free so far, I do agree with the post you linked to.
I am keeping my fingers crossed.
2017 M2.
2015 F31 320D.
flyboy777
Post by flyboy777 » Thu Jan 19, 2012 7:16 pm
Still no judder.
Watch this space!
2017 M2.
2015 F31 320D.
flyboy777
Post by flyboy777 » Mon Apr 02, 2012 2:33 am
Still judder free after a couple of thousand miles. 8)
2017 M2.
2015 F31 320D.
London Rundem
Post by London Rundem » Mon Apr 02, 2012 7:44 am
Lucky for you its not happening anymore :)
I ended up forking out for new clutch and flywheel @ 35'000 miles :!:
david in germany
Post by david in germany » Mon Apr 02, 2012 10:00 am
you get the same benifit if you do an occasional 2nd gear start.
2009 E87 118i, Bilsetin B8 with BMW Performance Springs filled with audio gear. <-mine
2011 E90 328i M Sport, 335I brake upgrade. <- wifes
2009 E90 335I Msport , Cobb tune, Other stuff. <- Mine
Wibbles
Post by Wibbles » Mon Apr 02, 2012 10:13 am
The official BMW fix is a DME software upgrade that keeps the idle revs higher.
BRD on Facebook
London Rundem
Post by London Rundem » Mon Apr 02, 2012 3:11 pm
Wibbles wrote:The official BMW fix is a DME software upgrade that keeps the idle revs higher.
How much does this cost Mr Wibbles ? :D
davidv111
Post by davidv111 » Mon Apr 02, 2012 10:39 pm
I had this problem with my 120d, i rang up wollaston bmw, they booked it in for a day, said yes there is clutch judder, rebooked it the next week for 4 days and replaced the clutch and flywheel all on warranty, no arguing no quibbling, they just got on with it and did it
Very impressed by this, if its still in warranty or AUc warranty, take it to the dealer, and you may get the same level of service as i did :)
Now: Snapper Rocks Blue 440i Auto; Dynamic & M Sport + packs, digital dash & more
Previous:
Estoril LCI M135i Manual
Thunder grey 2013 MINI JCW GP
Slate grey Porsche Cayman 2.7
Sapphire black E82 120d M Sport
flyboy777
Post by flyboy777 » Tue May 15, 2012 5:03 pm
Still no judder :wink:
2017 M2.
2015 F31 320D.
BMWbaz
Post by BMWbaz » Tue May 15, 2012 5:17 pm
Had my 2008 118d a month and I've got this issue! Booked it in where I bought it, it came with 3 months warranty luckily !!
Autodelta
Post by Autodelta » Wed Sep 26, 2012 4:01 pm
Just had a new clutch and flywheel fitted by Sytner due to the same judder when cold - 123d with 28k miles. Thankfully it was covered under warranty! Apparently the flywheel and clutch plate were contaminated with fluid (oil?).
Post by Octavius » Wed Sep 26, 2012 4:21 pm
Mine had a software update two weeks ago. So far so good.
DEFECTED TO SKODA.
Flying_Scotsman
Post by Flying_Scotsman » Wed Sep 26, 2012 7:21 pm
Autodelta wrote:Just had a new clutch and flywheel fitted by Sytner due to the same judder when cold - 123d with 28k miles. Thankfully it was covered under warranty! Apparently the flywheel and clutch plate were contaminated with fluid (oil?).
Crank shaft oil seal or the seal on the gearbox side could be leaking. If they fixed neither
And it was contaminated badly, prepare for the judder to return! :shock:
