What Did You Do To Your 1 Series Today?
EB2429
Post by EB2429 » Sat Mar 23, 2013 4:10 pm
Haven't seen a thread like this on here, So the idea is to post up what you did to your 1 Series. Types of things to post could be cleaning, maintaining, modifying, piloting it around a track, etc. Post pics if you can. This thread could inspire others to do something similar. I'll start...
Well as the weather was so bad I decided to paint the discs and calipers front and rear in silver and black to prevent the dreaded orange rust from showing through the wheels. And while was at it i fitted the Mud guards, strangely I didn't need to modify the mud guards for the M-Sport (I though it was essential).
Whenever anyone clicks on a 'Like" icon (on Facebook or elsewhere), a popup should appear that reads: "Popularity is not the same as quality. Proceed anyway?”
Re: What Did You Do To Your 1 Series Today?
Post by marco_polo » Sat Mar 23, 2013 4:28 pm
Did you have to modify the rear mudguards a little? Fronts will fit straight on.
All I did to mine today was use her in a 'enthusiastic/spirited' fashion. :D
It's been a busy week though, injector refurb, swirlflap-ectomy, new glow plugs, inlet manifold cleanout, new PCV Breather and new air filter.
chall5
Post by chall5 » Sat Mar 23, 2013 4:35 pm
Snow foam wash
E82 135i DCT N55
E82 123d
E36 320i
E30 318i
Rich196
Post by Rich196 » Sat Mar 23, 2013 4:41 pm
Finally picked it up from the dealers after having both the turbos replaced! A very happy 1er! Pulling like a train!
Sent from my HTC Desire S using Tapatalk 2
EB2429
Post by EB2429 » Sat Mar 23, 2013 4:44 pm
marco_polo wrote:Did you have to modify the rear mudguards a little? Fronts will fit straight on.
Ahh... that explains it, i thought both sets needed modding.
Only fitted the front to protect the sill and door.
ftb101
Post by ftb101 » Sat Mar 23, 2013 4:54 pm
Just wondered why have you an axle stand under the hub edge?
Also, what paints did you use for the caliper and disc? It looks like you've done a great job. Wish I had a usable garage for this sort of thing...
Regarding your mudflaps, the only modification you need to perform on the front is shaving off a tiny plastic tab. The plastic tab fits between the plastic sill trim and the bodywork on the other trim levels, but it's in the wrong place on the M Sport trim. You may not have noticed it, it is very small and takes just a second to lop it off! It is the rear flaps that require major surgery though...
Edit: just seen your second picture and the plastic tab is in the correct place! I had to shave mine off to fit, weird huh?
Alpine White E87 123d ///M Sport
EB2429
Post by EB2429 » Sat Mar 23, 2013 5:34 pm
ftb101 wrote:Just wondered why have you an axle stand under the hub edge?
I carried out the camber pin mod at the same time and was just seeing if I could lower the car a fraction and push the strut inboard at the same time to save leverage on the paint at the top, to do this I thought I needed to take some load at the outer edge of the geometry (worked on other cars). It didn't work as i wanted it to, so I jacked it back up 10mm and left it there as i forgot, and used 3 layers of card and a wrench on the top of the strut.
My pin was a soft dome and not very pronounced, so i just drilled it after masting off the strut brace and area around the pin (in case i slipped).
I used one of the spare mud guard speed fit plugs to drop into the hole to make it look a little more factory fit.
The paint was black and silver Hammerite 250ml tins and throw away small brushes
mareeno
Post by mareeno » Sat Mar 23, 2013 6:58 pm
Oil + filter air filter + fuel filter :mrgreen:
BILSTEIN B6 SHOCKS, EIBACH SPRINGS, MV3 ALLOYS CONTI SPORT 3, AERO SPOILER, BLACK CARBON FIBRE BADGES, MILLTEK, MTEC BRAKE DISCS, EBC YELLOW STUFF PADS, POWERFLEX BUSHES
markbarry1977
Post by markbarry1977 » Sat Mar 23, 2013 7:21 pm
I live on an raf base that only flies during the week, I therefore had the worlds best snow playground to test my drifting and snow driving techniques on.
Ace day. Having just recently gone from front to rear wheel drive I have through had to learn to depress the clutch when using the handbrake.
M135i F20, 2016, Auto, Comfort, Pro Nav, HK
370z GT Roadster, 2010, White
GREATEST DRIVER EVER
I want to be able to drive like THIS:
muz1990
Post by muz1990 » Sat Mar 23, 2013 7:49 pm
Walked past it in the driveway this morning on my way in from a night out last night :lol:
It's clean though!
And il be out in it tomorrow night :D
previous- Etune stage 1 n54 135i with lots of bits and pieces
now - mtm stage 1 Audi TT-RS in ibis white with bad-boy bucket seats!
mareeno
Post by mareeno » Sat Mar 23, 2013 8:29 pm
Hay muz that must have been sum swally next you will be telling us your driveway was longer on the way home :lol:
stefan
Post by stefan » Sat Mar 23, 2013 8:45 pm
Sold it!
Post by Octavius » Sat Mar 23, 2013 8:46 pm
muz1990 wrote:Walked past it in the driveway this morning on my way in from a night out last night :lol:
It's clean though!
Night out. Ok, truth time. What's she called ?
mikehunt
Post by mikehunt » Sat Mar 23, 2013 8:52 pm
Arthur.
:lol:
muz1990
Post by muz1990 » Sat Mar 23, 2013 9:07 pm
mareeno wrote:Hay muz that must have been sum swally next you will be telling us your driveway was longer on the way home :lol:
Not anymore haha! :lol:
And I was out with some friends in Glasgow, went to a jazz bar then clubbing and it was a sh1thot night out :D
Much needed lol, having a few tinnies tonight to take the hangover away ;)
