What Did You Do To Your 1 Series Today?
Dirty_badger
Re: What Did You Do To Your 1 Series Today?
Post by Dirty_badger » Fri Jan 12, 2018 7:52 pm
Post removed as it caused offence
BMW E82 123d M Sport
Post by Twenny » Fri Jan 12, 2018 9:08 pm
Dirty_badger wrote:I take on board all your comments but at the end of the day they're tinted and will be staying that way until I get made to take them off.
Which I've had every car I've owned done and not once been pulled for my tints.
Had a feeling you’d say that.
You could switch your fog lights on too then you’ll look even more cool bruv innit lol
Jack@AUTOID
Post by Jack@AUTOID » Sat Jan 13, 2018 11:20 am
CraigG wrote:
Fri Oct 20, 2017 9:11 am
Fitted Performance Short Shift kit and handbrake:
Before:
After:
How much did the short shift kit cost you to get fitted out of interest?
AUTOID
autoid.uk.com
jack@autoid.uk.com
‭020 7205 2429‬
E81 130i LE
BMWP Short shift kit, Handbrake, Front Bumper, Side skirts. 15mm spacers all round. Res delete. + few more bits.
Graearea
Post by Graearea » Sat Jan 13, 2018 2:38 pm
Imageautosport intl. Lust is such a strong word.
Quaife.
Rustle
Post by Rustle » Sat Jan 13, 2018 6:25 pm
Started stripping for a rear roll cage install in Feb.
E87 '05 130i; BMWP Brakes, intake, & exhaust. birds arb's, quaife, meister R coilovers, m3 lca, goodridge lines, oz Ultraleggera and 595 RSR's.
Graearea
Post by Graearea » Sat Jan 13, 2018 8:28 pm
Rustle wrote:Image
Build thread!!!!
Rustle
Post by Rustle » Sat Jan 13, 2018 10:48 pm
Graearea wrote:
Rustle wrote:Image
Build thread!!!!
I’m not sure it’ll be that exciting but I’ll take a few pics after this round of tinkering and see how it goes.
CraigG
Post by CraigG » Sun Jan 14, 2018 10:27 am
The kit itself was about 130 from Harry Fairbairn. And I just fitted it myself. took about 15 mins start to finish, hardest bit for me was getting the old plastic collar turned to the right position to remove it
130i Msport - Sapphire Black - KW V2, BMWP Exhaust, BMWP Short Shift Kit, BMWP Grills, LCI Blackline High
Jack@AUTOID
Post by Jack@AUTOID » Sun Jan 14, 2018 4:50 pm
Interesting! I’ve been quoted £120 and two hours to fit...
I’ve got the gear knob, gator and new short linkage. Is that what you got?
AUTOID
autoid.uk.com
jack@autoid.uk.com
‭020 7205 2429‬
E81 130i LE
CraigG
Post by CraigG » Sun Jan 14, 2018 11:01 pm
yea no way it would take 2 hours...
its all done from inside the car! only fiddly bit is getting the old linkage out
supercati
Post by supercati » Mon Jan 15, 2018 10:47 am
I'm also looking forward to do this, I have at home the Short Shift Kit waiting to be fitted, but I didn't found too much info on how to install the new short leveler.
How do you remove the lever / leveler? And how do you install it? Specially the lower clip #6 (do you need a new one btw?)
130i E81 2007 LHD - Sparkling Graphite Metallic / Boston Terra - CDV Delete - 135i ESD with resonator delete - LED Blacklines - RIP :(
130i E81 2008 LHD - LSE / Boston Terra - Complete HiFi Retrofit - CDV Delete - LED Blacklines - BMWP SSK -
CraigG
Post by CraigG » Mon Jan 15, 2018 2:52 pm
number six is just a circlip, i used a pair of needle nose pliers to remove it, also, the kit comes with a replacement one, so no worries if you kill it taking it off.
handy how to guide from this very forum :)
http://www.babybmw.net/howtos/how_to-_f ... _lever.pdf
The hardest bit for me was rotating the white collar into the unlock position. again i used the needle nose pliers in the two slots and twisted. if you look at the new unit, you will see how the locking mechanism works.
supercati
Post by supercati » Mon Jan 15, 2018 2:58 pm
Thanks Craig :D Understood! And happy to know everything can be done from the inside.
I will buy (just in case) another #6 because I don't have any spare one on my kit (second hand).
Wayno
Post by Wayno » Wed Jan 17, 2018 12:06 am
No winter tyres. Decided to leave it on the street and walked home after getting stuck in the middle of the road.
2010 118d 220BHP 340lb/ft
4x18x9J ET33 Inovit Thrust Wheels
Uniroyal Rainsport 3's 225/40/18 - 235/40/18
Ecotune Stage 1 Remap by Stan
Aero Spoiler
Eibach Pro-Kit Lowering Springs
Pipe Dynamics Custom Exhaust
CraigG
Post by CraigG » Wed Jan 17, 2018 11:40 am
silly cookie :P
i had to drive round people both yesterday and this morning. we need to adopt the mandatory winter tyre laws like our European counterparts....
