What Did You Do To Your 1 Series Today?
Dan116i
Re: What Did You Do To Your 1 Series Today?
Post by Dan116i » Sat Mar 17, 2018 7:51 pm
GermansMastery wrote:
Sat Mar 17, 2018 6:00 pm
haha apologies mate!
Dan116i wrote:
Sat Mar 10, 2018 6:00 pm
Removed the stainless steel exhaust tips on the BMWP exhaust and fitted carbon ones.
Hi Dan.
just want to say love how your car looks mate! Regarding the exhaust tips. could you link me where you got the double exhaust from? is it as simple as just fitting the exhaust tips onto end of OEM? thanks
Cheers :)
So OEM 130i exhaust tips push straight on. I’ve got the BMW Performance exhaust with welded tips. So I had to remove the welds first. I got the tips from Aliexpress for around $40 each. 73mm inlet, 76mm outlet and asked for them to be 10cm long (they come as 17cm standard). The inlet size will most likely be different on an oem exhaust. These bolt straight on
https://m.aliexpress.com/item/328253623 ... b752pXK2cC
Hope this helps :)
Now: 2006 130i with even more goodies ;)
Gone: 2008 116i with goodies :)
GermansMastery
Post by GermansMastery » Sun Mar 18, 2018 4:32 am
Hi Dan.
Cheers :)
Hope this helps :)
Awesome buddy thanks for the tip. I’m really quite a noob when it comes to exhaustsImage I’m more about the aesthetics.
So my 116i has that ugly oval shaped exhaust. So I’m sure I could fit one of them one. What I really want is the double exhaust tips like yours. Will that require a new backbox. I’ve seen on eBay exhaust tips that are attached to one(linked below) would they be alright. I really like the look of the alinexpress ones you linked but I want to go for the double exhaust look without actually having to change around the underneathsImage
https://rover.ebay.com/rover/0/0/0?mpre ... 1980880202
Thank you
Dan116i
Post by Dan116i » Sun Mar 18, 2018 8:17 am
Ah..... in that case it’s going to be a new backbox really. Unless you start chopping and welding the existing one
Webarno
Post by Webarno » Sun Mar 18, 2018 2:59 pm
Took some pics...
2009 E82 125i M Sport LeMans Blue
https://www.instagram.com/webbybm/
Stealth328Ci
Post by Stealth328Ci » Sun Mar 18, 2018 3:35 pm
Hey Webby!!
Car is looking so nice!! Love that colour!!
Bryan aka Stealth!!
Titan Silver E82 125i M Sport Coupe
Webarno
Post by Webarno » Sun Mar 18, 2018 3:43 pm
Hey Webby!!
Bryan aka Stealth!!
Thanks man!
Wish it looked that clean right now though.
This poor weather drives me nuts :(
Stealth328Ci
Post by Stealth328Ci » Sun Mar 18, 2018 3:46 pm
Hey Webby!!
Bryan aka Stealth!!
Thanks man!
Tell me about it, its affecting business!!
Think I need to invest in one of those gazebo tent things and long term look for premises! Somewhere with some heating! :D
fmn716
Post by fmn716 » Sun Mar 18, 2018 3:48 pm
Webarno wrote:Took some pics...
sh*t this looks hawt ImageImageImage
Webarno
Post by Webarno » Sun Mar 18, 2018 3:53 pm
Stop... I'm blushing! :wink:
fmn716
Post by fmn716 » Sun Mar 18, 2018 5:02 pm
So the few mods I have done for my cone is a heat shield and I have run an intake pipe through my fog
My passenger fog light was already damaged so I decided to do a little bit of test fitting for an induction pipe and it works !!!
Here was my fog totally farked Image
Got creative and cut that biatch up lol
Flexible pipe was a purrrfect fit Image
Cone back on with heat shield should be a nice improvement. Due to heat my car lost 10wkw so yeah it’s a big problem
ZKhalid
Post by ZKhalid » Sun Mar 18, 2018 5:02 pm
Being that my E88 is the first rear wheel drive car I've owned I've always wanted to..
Yes I held DTC for 5 seconds 😁
_Declan_
Post by _Declan_ » Sun Mar 18, 2018 11:22 pm
Took some pics...
Hey, our cars are almost identical! :D
Webarno
Post by Webarno » Sun Mar 18, 2018 11:23 pm
Good taste Declan! 😉
paddyboy
Post by paddyboy » Mon Mar 19, 2018 2:13 pm
Auto box on my 130i had a service this morning .... new filter, gasket + oil
I have a GM box which takes Dexron VI fluid - the stuff that came out was original (on 65k miles) + not too bad slightly darker than the new stuff going in but there were metal filings on the magnet in the sump which was obviously doing its job
All running very smoothly no clunking thru the gears as I had expected as the box has to 'relearn' the driving style
All very competently carried out by a Dutch man in Marsden, West Yorks :D
redwizard
Post by redwizard » Mon Mar 19, 2018 2:17 pm
Next time you see him, tell him Barrie says "Hi, and how's my quote coming along". :)
