What Did You Do To Your 1 Series Today?
barneyrubble
Re: What Did You Do To Your 1 Series Today?
Post by barneyrubble » Thu Apr 12, 2018 9:02 am
Think bigger :D :D :D
If it's got breasts or wheels - it's going to give you trouble
BMWBrad
Post by BMWBrad » Thu Apr 12, 2018 11:18 am
Fine choice!
Absolutely love the M2!
I need a better paid job, must have one in my life :roll:
Pampered E81 130i
(Alpinweiss, Black Boston, Cruise, Adaptive Xenons, Pro HU w/BT, USB & DAB, F&R PDC)
BMWPE- BMWP SSK- BMWP Handbrake- BMWPV1 Steering Wheel- Alcantara Binnacle- L7 Mids & Tweeters
Dirty_badger
Post by Dirty_badger » Thu Apr 12, 2018 1:05 pm
Hit a massive pot hole, damaged alloy and bumper. ImageImageImage
BMW E82 123d M Sport
Post by Twenny » Thu Apr 12, 2018 5:28 pm
Dirty_badger wrote:Hit a massive pot hole, damaged alloy and bumper.
Holy fish that’s not a pot hole!!!! That’s a crater!!!
You can see the earths crust in the bottom!!!
Dirty_badger
Post by Dirty_badger » Thu Apr 12, 2018 5:35 pm
Just need the bumper sorting now Image
Post by Twenny » Thu Apr 12, 2018 5:37 pm
Dirty_badger wrote:Just need the bumper sorting now Image
I also like to drive naked DB lol
Dirty_badger
Post by Dirty_badger » Thu Apr 12, 2018 5:39 pm
Haha
Dirty_badger
Post by Dirty_badger » Thu Apr 12, 2018 5:57 pm
900x1000x120mm the hole was. ImageImageImage
StrangelyBrown
Post by StrangelyBrown » Thu Apr 12, 2018 6:36 pm
Found the mythical 12v socket located under the glovebox :)
125D M Sport auto - With additional stuff.
Demelitia
Post by Demelitia » Sun Apr 15, 2018 8:28 pm
130i LE. Changed the diff and gearbox oil the other week, CDV delete at the same time. Performance filter element installed in the standard air box. Not long before that new Vanos solenoids.
Treat it to a brand new set of style 216 wheels, wheel bolts and centre caps. GY eagle F1 non rf; 225/40/18 front, 255/35/18 rear.
~£30 of bolts and fasteners replaced under the bonnet and gave it a quick detail. It needs a proper going over but it’ll have to wait until it’s not chucking it down and there’s still a few rusty fasteners I forgot to order.
Today; Performance shift knob, steering wheel trim, handbrake lever and gaiter. Ordered a performance gear gaiter from an e90. Hopefully going to take the alcantara off the frame and stick it on to mine as the e8x gaiter is unavailable now. Received the engine oil and filter from Opie for its 6000 miles change.
Cleaned and conditioned the steering wheel.
Edit: spent 30 minutes reading back through this thread finding new ways to spend money on things I want. (Need?)
the obese penguin
Post by the obese penguin » Sun Apr 15, 2018 8:35 pm
Changed the wipers. Old ones were squeaking like crazy.
Skibob
Post by Skibob » Sun Apr 15, 2018 9:34 pm
130i, I changed the little white shift lever bearing today, for £9 it has made a good difference to the gear changes, still got the M3 mounts, CDV mod and gearbox oil change to do but doing each bit at a time to compare the difference each bit makes.
slindborg
Post by slindborg » Mon Apr 16, 2018 7:58 am
Not today, but the past week :lol:
New turbo core fitted, turbo assembly fitted, turbo primed, all rebuilt.
Scariest restart of a car ever.
Still made a damn racket
Sit and pondered life lots...
Saturday I took the turbo out to check it was ok, it is thankfully.
I then decided to hunt this sodding boost leak down with gusto.
I took the intercooler out, both boost hoses and the EGR valve off, and built this
Now, MDF can only take 20PSI on its surface before it leaks out to the sides :lol: Added a bit of palstic and all was well enough to get the system to 35psi and saw this
Cant tell you how happy I am to see a leak!!!!! new seal on order, rig kept in tact so that the new one can be tested prior to install.
MPN1
Post by MPN1 » Mon Apr 16, 2018 8:59 am
Changed the camshaft cover gaskets and spark plugs.
2007 130i le m sport. Bilstein B6 Rears with Powerflex Mounts. Camber Pin Mod. BMWP Grilles. Royal Steering Wheel.
MattR8700
Post by MattR8700 » Mon Apr 16, 2018 12:21 pm
Itsteagle wrote:
MattR8700 wrote:
Tue Mar 27, 2018 1:02 pm
I gave the EGR valve a clean up as it had been playing up ever since I brought the car. YouTube videos imply it’s a 10 minute job to remove, it took nearly 90!
Any improvement?
It’s been 3 weeks, and it’s not played up once, so I’d consider that a win!
- Black 2009 E87 118d MSport -
