E82 2009 125i Msport 1-2 shift (manual)
MSTRKRFTSMN
Re: E82 2009 125i Msport 1-2 shift (manual)
Post by MSTRKRFTSMN » Sun Jan 29, 2017 5:43 pm
No worries guys. Nice to be able to give a little back to the forum. Thanks for the feedback.
2009 E82 125i M Sport, Black Sapphire.
Mods: CDV delete, 125i debadge, 160w Angel Eye White LEDs, Silvertec indicators
viewtopic.php?t=86644
Scorp
Post by Scorp » Mon Jan 01, 2018 12:26 am
I'll definitely be doing this as 1st to 2nd and 3rd to 2nd catches sometimes..
Post by Octavius » Mon Jan 01, 2018 11:59 am
The white plastic bearing clips out from the top. Just takes a bit of doing but that's how, not from underneath. Takes about twenty minutes from start to finish and don't forget to grease it up.
If you look at the new one you can see the splines that hold it in position. Just push these in and rotate it and it should lift out.
riccie_120i
Post by riccie_120i » Thu Jan 18, 2018 4:13 pm
Hello,
I just tried to do this, and bought a brand new plastic bearing. However, I could not get the bearing to slide down the gearstick shaft, no matter how I tried. So are you absolutely sure the bearing just lifts out and over?
My gears were a bit grabby and sticky between 1- and 2 so I thought I'd give this a go.
I bought a new bearing from Cotswold BMW.
Followed this guide to get the gear knob off and the gaiter too. That was all easy peesy, even the gearknob came loose without too much struggle.
this is what I was faced with
https://drive.google.com/file/d/1p3PJ3U ... sp=sharing
the ball was a bit grubby and definitely dry, so I went through the gears and cleaned it up with PTFE lubricating spray.
However, as you can see, there is absolutely no way the new bearing fits over. It is just too small??
https://drive.google.com/file/d/1hfMe3- ... sp=sharing
I did find lots of pieces of debris which were slowly working their way out, such as this
https://drive.google.com/file/d/1ke9UGZ ... sp=sharing
Removed several of these.
and these https://drive.google.com/file/d/1o6kOR- ... sp=sharing
Ideally I'd have removed the bearing but a) I was struggling to get it to unclip, and b) well, as you see above the new bearing would not go over anyway..
I did follow the tip about rotating it slightly, and then greased it quite liberally with copper grease.
https://drive.google.com/file/d/1KP36an ... sp=sharing
Well took it round the block and much improved. I am annoyed I could not seem to replace the bearing. The housing is just too small to go over. Wring part? does the shaft come off? anyone know??
riccie_120i
Post by riccie_120i » Thu Jan 18, 2018 4:22 pm
hmm,
Cannot quite work this out. https://www.newtis.info/tisv2/a/en/e87- ... on/OzFzM6I
does that mean if the bearing is lifted the bering is removed from underneath?
Perhaps Octavius or someone can clarify..
riccie_120i
Post by riccie_120i » Thu Jan 18, 2018 4:29 pm
So close yet so far :shock: :x :evil: :twisted:
:lol:
Answer is here for anyone interested. http://www.babybmw.net/howtos/how_to-_f ... _lever.pdf
I've put mine back together again now!
