AUTOBRITE "BRILLIANCE"
Stealth328Ci
Post by Stealth328Ci » Sun Aug 09, 2015 10:45 am
Hi all,
I cannot recommend this product enough, I tried it out on my car and it gave fantastic results and was simple to apply and remove.
Quoted from Autobrite Directs website;
BRILLIANCE
Brilliance. The exquisite glaze from Autobrite Direct, designed specifically to mask swirls and add a layer of protection, provided by the fine quality montan and crystalline waxes expertly blended into delicious blackberry scented Brilliance. Effortless in application, Brilliance is best applied by hand, but equally at home being applied by a machine with a finishing pad. A fascinating feature of Brilliance is that it is perfectly at home on metallic, pearlescent and standard gloss finishes. It can even be applied in strong sun and high temperatures with no detrimental effect. Marvel at the Brilliance!
Titan Silver E82 125i M Sport Coupe
roshambo
Re: AUTOBRITE "BRILLIANCE"
Post by roshambo » Sun Aug 09, 2015 10:55 am
Did you use a DA? I find it interesting that its used to mask swirls. Most people who look to buy these products won't have swirls in the first place ;)
Matt
Current: 2015 F36 435i M Sport
Old: 2013 F20 116d Sport; 2006 E87 120d M Sport
Stealth328Ci
Post by Stealth328Ci » Sun Aug 09, 2015 11:12 am
Hey Matt,
No I just applied it by hand, I did have some slight swirls on the bonnet hence buying this product, they are now completely gone! Very surprising considering I didn't use a DA, it is something I want to learn to use eventually but with products like this Ill never have the need!
Dan183
Post by Dan183 » Mon Aug 10, 2015 12:59 pm
Stealth328Ci wrote:Hey Matt,
That wont have removed them. They're still there and will start showing in 4-6 weeks
M135i / F20 / AW / Auto / Pro media / Comfort Pack / HK / Heated Seats / Comfort Access / Extended Storage
BMWP Grill / BCS V2 / Carbon Mirrors
Stealth328Ci
Post by Stealth328Ci » Mon Aug 10, 2015 1:03 pm
What should I do to remove them permanently?
Dan183
Post by Dan183 » Mon Aug 10, 2015 3:11 pm
Stealth328Ci wrote:What should I do to remove them permanently?
Use a DA/Rotary.
I find Megs 105/205 on lake country pads work well.
If you're near Birmingham il happily give you a hand
Stealth328Ci
Post by Stealth328Ci » Mon Aug 10, 2015 4:08 pm
Thanks for the offer that's very nice of you, unfortunately I'm in London.
