LCI e82 rear lights - 4 different part numbers!!
Post your thoughts in here
nwmark
Post by nwmark » Mon Mar 04, 2013 8:22 am
Can anyone tell me the difference between the rear light LCI part numbers, i understood that one is LED and one not, but looking on realoem there are 4 different part numbers, depending on whether the car has sports/xenons/adaptive lights, but there are some overlaps.
such as they list two pairs of different part numbers for the same options e.g.
Car options- Sports- Yes, Xenons - Yes, Adaptive = No, 03/2011+
63217327275 63217327276
63217327273 63217327274
And there is another pair of part numbers for cars that dont have the sports edition. (what did Sports edition add to the rear lights) i was guessing darklines, but the part numbers dont match up (63212225282 for darklines)
63217273427 63217273428
Any ideas whats going on?
or maybe more simply which ones id need if adding to an e82 with xenons and pre-LCI rear LEDs?
p.s. the last set of part numbers is for cars with none of the options are 63217273429 63217273430 making 4 different part numbers!!!
Flywalker
Re: LCI e82 rear lights - 4 different part numbers!!
Post by Flywalker » Thu Mar 07, 2013 9:19 pm
The following numbers are non dark line LCI LED rears..
These are what I retrofitted to my pre LCI e82 with xenons . They were plug n play & worked a treat.
It's a mod worth doing. Slightly brighter lights with a fresher look..
ps did I tell you I'm about to advertise my them in the "for sale" section !!
Mo110
Post by Mo110 » Thu Mar 23, 2017 2:06 am
Would these be plug and play on a 08/2009 120d e82?
Post by Twenny » Thu Mar 23, 2017 9:01 am
Mo110 wrote:Would these be plug and play on a 08/2009 120d e82?
Lol 4 years old so don't expect an immediate reply buddy.
I see you've requested dark lines for your car from Cotswolds.
As long as you have the rear cluster 3 strip LEDS the darklines you've ordered will be plug and play regardless of xenons etc.
