E82 Heated steering wheel retrofit possibility
Post your thoughts in here
RichIbizaSport
Re: E82 Heated steering wheel retrofit possibility
Post by RichIbizaSport » Sun Jan 25, 2015 11:28 pm
I do have a rain sensor, light sensor + multi function steering wheel
'59 as in second half of 2009 UK registered :)
I just put my VIN into:
http://www.bmwarchive.org/vin/bmw-vin-decoder.html" onclick="window.open(this.href);return false;
S248A
Lenkradheizung Steering wheel heater
Looking at realoem it looks like my wheel is 32306795573 but I have paddles. Manual transmission heated sport wheel is 32306795571
It doesn't look like it's an option with the m-sport wheel.
Hopefully that gives you something to go on
'59 123d coupe
--help
Post by --help » Mon Jan 26, 2015 10:49 pm
Wow, they do exist! :spotman:
Can you go to realoem, type your VIN and search for 'steering column'. It is called "Switch unit steering column" to be exact. So far, i found no e80-series BMW that had the option S248=Yes (heating) and S521A=Yes (rain sensor) and S540A=Yes (cruise control) ... Can you maybe check that for me? Thanks!
Edit, i did found an E92 steering column with all options, but i am unsure if this would work ... (http://www.realoem.com/bmw/showparts.do ... fg=35&hl=7" onclick="window.open(this.href);return false;)
RichIbizaSport
Post by RichIbizaSport » Tue Jan 27, 2015 1:06 pm
Here yo go :)
That looks to be the only one with the heater.
'59 123d coupe
--help
Post by --help » Tue Jan 27, 2015 11:10 pm
But you said to have a rain sensor, this one doesn't (S521=No).
RichIbizaSport
Post by RichIbizaSport » Tue Jan 27, 2015 11:17 pm
I do have a rain sensor. I couldn't find one with heater and the rain sensor!
*edit*
OK I think it's probably part number: 61319169753
All of those have the the heater (S248A=Yes) at the very top, do you notice how it has the i (in italics), then it goes down the list adding cruise, rain sensor, adaptive cruise etc.
*second edit*
http://www.etk.cc/bmw/EN/search/selectG ... 1319169753" onclick="window.open(this.href);return false;
that give you a pretty clear answer
'59 123d coupe
--help
Post by --help » Wed Jan 28, 2015 8:15 am
But this one is for E90-series BMW. So your car wasn't equipped with either of the options from the factory in that case? Or would that mean that the E90-series steering column would fit on the E80-series?
RichIbizaSport
Post by RichIbizaSport » Wed Jan 28, 2015 1:07 pm
You're not really understanding what I'm saying
http://www.realoem.com/bmw/showparts.do ... g=61&fg=35" onclick="window.open(this.href);return false;
Look at that page. All for the e82. All of the switch clusters on that page support the heated wheel.
The difference is cruise, rain sensor etc.
I'm almost certain my car will have 61319169753, which supports the heated wheels and a rain sensor, not cruise control.
So 61319169753 is the option for:
S248A=Yes (heated)
S521A=Yes (rain)
S540A=No (cruise)
S544A=No (cruise with brake)
'59 123d coupe
--help
Post by --help » Wed Jan 28, 2015 4:09 pm
Ah, i get it! So you don't have cruise control. Correct?
RichIbizaSport
Post by RichIbizaSport » Wed Jan 28, 2015 4:26 pm
--help wrote:Ah, i get it! So you don't have cruise control. Correct?
I don't. I wish I did!
'59 123d coupe
--help
Post by --help » Wed Jan 28, 2015 10:17 pm
Yeah, totally understand you. I have cruise control and automatic wipers and would not want to loose them, especially not the cruise control!
So, still wondering ... would this one fit/work? 61319169755
Post by marco_polo » Wed Jan 28, 2015 10:42 pm
Might do, as you don't have a rear wiper either.
--help
Post by --help » Sat Jan 31, 2015 2:09 pm
marco_polo wrote:Might do, as you don't have a rear wiper either.
How you mean, might do? I would think it works, as i have been reading that E90 and E80-series usually have interchangeable parts!
Post by marco_polo » Sat Jan 31, 2015 2:13 pm
Yup, they're usually interchangable, so it should work.
--help
Post by --help » Sat Jan 31, 2015 6:37 pm
marco_polo wrote:Yup, they're usually interchangable, so it should work.
That'll do it for me, will scout second hand sites for one! And update this thread when i have some more information 8)
Wobble
Post by Wobble » Sun Feb 01, 2015 12:58 am
I would love this,had it in my 2011 Z4,my 120d m sport has everything apart from the heated steering wheel,and this is something I'd defo pay to add to my car x
