after-market xtrons double din astray reloaction
mickey_mellen
Post by mickey_mellen » Tue Jan 09, 2018 6:17 pm
Hi all, I'm driving a bmw 09 120i coupe, I have recently purchased and installed the xtrons PF7581BAP, and i absoluety love it, does everything i possibly need it to do, sat nav, bluetooth etc, however after installing i've realised the button panel for the stop/start, parking sensors etc can't be housed, now i've tried removing the panel and i can't turn off the reverse beep without turning the car off then back on again, so thats not the answer, also i've been told that the ashtay infill in an E46 is the same as the E82 i'm currently driving, as this has the necessary panel to accomadate the buttons. Any help would be amazing as i'm at a a loss as to what to do with it.
LanceG
Re: after-market xtrons double din astray reloaction
Post by LanceG » Fri Mar 09, 2018 2:38 pm
I'm sure you can get the sunglass box with a cutout for this...
http://www.janus-design.net/english/acc ... /index.php
120d SE - M sport suspension | eibach pro lowering springs
GarySwallow
Post by GarySwallow » Thu May 10, 2018 12:30 am
Hi
Does this unit show the front/rear parking sensors on screen?
Did you need any external canbus adapter or is it all included in the kit you purchased?
Do all the warning tones play through the speakers correctly (eg when reversing near something on the left..the beep for the sensor comes from the rear left speaker)?
