Son of Skippy - Marco's M-Lite - Now with Mini Cooper Exhaust Tips.
nickfrog
Re: Son of Skippy - Marco's M-Lite - Now with M235i Front Springs!
Post by nickfrog » Fri Jan 22, 2016 9:43 pm
marco_polo wrote: Please could you copy and paste those torques over, just in case anyone else follows this?
According to BP :
Lower control arms to knuckle 122 ftlb (165 Nm)
Lower control arms to subframe 74 ftlb (100 Nm)
Megane RS Cup-S - due early June 2016
LCI M135i 3-dr, manual - bought June 15 - Sold May 16
Toyota GT86 - bought Nov 14 - Sold May 15
E82 125i M Sport on 130i power and brakes, MSS tyres - sold NOV 14
Post by marco_polo » Fri Jan 22, 2016 9:49 pm
Thanks Chap. It seems guesswork is the best-work! :lol:
Are yours fitted now? :D
nickfrog
Post by nickfrog » Sat Jan 23, 2016 2:24 pm
No I have just sent a RFP to Cotswold first, and if they can deliver quick I'll get my local guy to fit plus local alignment. I guess the added front lat grip will neutralise the car or did you have to find any additional rear camber (not sure that's even possible nor what it comes with as std?). Without a slippy diff I don't particularly want to compromise traction or stability under braking by having too aggressive a rear camber yet I wouldn't the car to be too oversteery. Also, what toe do you advise ?
I am pretty sure to fit Yokis Advan 105 too at the front to scrub them before the track day season...
Post by marco_polo » Sat Jan 23, 2016 2:33 pm
I'm running -1.8 camber at the back currently (plenty of adjustment back there), and basically zero front Toe (just a tiny smidge of Toe in).
Pretty neutral into corners now, switching to oversteer on the way out at my discretion.
I like to have a lot of confidence the the front end or I get a bit spooked tbh. The back end I can (more or less) sort out myself.
Keep us updated how you get on with the Advan 105's, I hear they're wonderful in the dry. :thumbs:
nickfrog
Post by nickfrog » Fri Jan 29, 2016 7:09 pm
marco_polo wrote:
nickfrog wrote:Hiya
ball joint off 37142283867 : sorry, is the regulator rod for the headlight ?
Any torque values for fitting the LCAs ?
Yes, you need to dismantle the M4 Reg Rod for one of the ball fittings (which you fit on with an M6 Nyloc or similar). You reuse your existing Reg Rod. All will become obvious once you see all the bits in front of you.
I think the inner bolts were about 100Nm, and the outer nuts about 165Nm? Double check that!!
Hello Sire, it's frog here. Right - I have the parts (great service from Costwold).
So do I remove one of the black parts that are "press pinched" in the tube ? If so, which one ? One of the threaded bolts is longer than the other ?
Or do I simply remove the metal bolt out of the rubber bit ? And if so which one ?
And then ? When does the M6 come into it ?
Nick
Post by marco_polo » Fri Jan 29, 2016 7:20 pm
nickfrog wrote:.
Hey Bud, you need to pop the ball joint (with the longest thread) out of the rubber cup.
Once removed, you fix that to your near side LCA using your M6 nut:
You're now ready for fitting. :)
Ah crap, it seems Photobucket is down currently?!
Oh, and remember to note/mark the height of your headlight beams before you start swapping arms (I've got a 'favourite' wall). The beam will be too high after fitting, but it's easily adjustable back to correct height with a 5 or 6mm Allen key through the Slam Panel.
nickfrog
Post by nickfrog » Fri Jan 29, 2016 8:12 pm
Great thx - I have marked the headlight height, cheers - what's the slam panel ? :lol:
Post by marco_polo » Fri Jan 29, 2016 10:01 pm
Might be my own nick-name for the horizontal panel that goes between the headlights?!
The headlight adjusters can be turned via access holes.
nickfrog
Post by nickfrog » Thu Feb 04, 2016 2:32 pm
Cheers. All ready for Saturday. The alignment place are asking if camber can be adjusted from underneath or using the struts under the bonnet ?
Post by marco_polo » Thu Feb 04, 2016 2:43 pm
Neither, you get what you get. Zero front camber adjustment anywhere on an F2*
Re: Son of Skippy - Marco's M-Lite - Now with Diseasil bits?!?!
Post by marco_polo » Tue May 10, 2016 3:45 pm
Updated with panel seals.
Blind Pugh
Post by Blind Pugh » Tue May 10, 2016 3:57 pm
marco_polo wrote:Updated with panel seals.
MP - reads like a bit of a red herring - sorry to waste your time and funds. BP
AW M2 DCT
Post by marco_polo » Tue May 10, 2016 4:05 pm
Just giving honest feedback to y'all. :) I'm not upset at all, but my gut reaction is it won't be a measurable improvement (on my dodgy phone app at least).
They've not obviously robbed any engine/exhaust roar, so not a step backwards, imo. Might be time to have a play with some closed cell foam over my rear arches though, or maybe just quieter tyres.... :chin:
Re: Son of Skippy - Marco's M-Lite - Now with Powerflex Inserts
Post by marco_polo » Sun May 21, 2017 2:00 pm
Updated with Powerflex subframe inserts: viewtopic.php?f=19&t=60691&p=755236#p755236
Post by marco_polo » Mon May 22, 2017 7:43 am
The inserts have only made a small improvement tbh, not as big a change as on my E87 despite them being the stiffer Black shore. Probably partly down to only fitting the lower halves.
The stock bushes are solid on the sides already, these inserts prevent excess fore/aft slop. I'm not too sad for £93 though, unless they fail my M20 noise test....
