Son of Skippy - Marco's M-Lite - Now with Mini Cooper Exhaust Tips.
Blind Pugh
Re: Son of Skippy - Marco's M-Lite - Now with Powerflex Inserts
Post by Blind Pugh » Tue May 23, 2017 9:35 am
marco_polo wrote:
Mon May 22, 2017 7:43 am
The inserts have only made a small improvement tbh, not as big a change as on my E87 despite them being the stiffer Black shore. Probably partly down to only fitting the lower halves.
The stock bushes are solid on the sides already, these inserts prevent excess fore/aft slop. I'm not too sad for £93 though, unless they fail my M20 noise test....
MP,
How is the NVH after a few days and more miles, post install ?
Any plans to install upper halves as well ?
BP
AW M2 DCT
Post by marco_polo » Tue May 23, 2017 9:52 am
Definitely no plans for the top halves, I've got at least one new high-pitch boot rattle to find, probably two.
Feels like I'm running an extra few psi in the rears, but without any of the associated loss in grip.
I'd guess the rear has improved 5-6%, and the steering 2-3%. Another small step towards feeling more like a full /M Car, but the pay-off is the vibrations (& the £90 of course).
Blind Pugh
Post by Blind Pugh » Tue May 23, 2017 11:48 am
Yes - I'm surprised you went for the black series TBH, given yr concerns abt NVH.
AW M2 DCT
Post by marco_polo » Tue May 23, 2017 12:18 pm
Yup, most probably a mistake. I was hoping the NVH wouldn't be too bad if I wasn't clamping the SF hard against the chassis, but I was wrong.
Post by marco_polo » Tue May 23, 2017 10:59 pm
2 new major boot rattles found and fixed. I might have a third, but it's very intermittent and quite feint, nothing the stereo can't drown out easily.
Bit of fine tuning next. I'm going to experiment with dropping the rear tyre pressures a psi tomorrow, I usually run 33/34 but will give 33 square a go.
Birdseye1
Post by Birdseye1 » Fri Jun 09, 2017 8:41 am
MP, can I ask how come you opted for black series over the 'normal' yellow ones? I'm in need of some rear end stability and while a diff is the long term answer, I'm hoping these might give a slight improvement. I assume yours is a daily too, so was there an NVH increase, and if so was it as bad as you feared?
And one more question if you don't mind...any ideas what a garage might charge? Approx 2 hours labour?
2014 EB M135i - More mods than I had planned to do... :roll:
Post by marco_polo » Fri Jun 09, 2017 9:50 am
Blacks were a bad choice, don't do it. Vibration and harshness are getting on my tits, I'm not sure whether to try cutting these down, or just ordering yellows. I'll probably end up doing both knowing me!
To fit all 8 rear inserts on a ramp with the right tools should only take about 45mins approx, if they're quoting 2 hours that's really taking the Mick.
Birdseye1
Post by Birdseye1 » Fri Jun 09, 2017 10:16 am
Ahh...sorry to hear! :cry:
I think I'll go for the yellows in that case and hope it's a marginal increase in NVH and the rear end stability is worth it. Ah ok was just guessing at the labour cost but having looked at the pics again doesn't seem to difficult so may just DIY.
Blind Pugh
Post by Blind Pugh » Fri Jun 09, 2017 10:33 am
Ditto - sorry that p/flex black inserts aren't working out for you MP plus fairplay to you for being critically honest about them. Hope cut down and or swapping to yellows works out.
Will fitting top halves effect subframe standoff/height relative to main body ie do they sit proud of existing bush or do they sit down below within existing bushing profile ??
AW M2 DCT
Post by marco_polo » Fri Jun 09, 2017 11:09 am
The top halves are very small, I doubt they'd alter the SF height.
2 ticks, I'll take a photo of a top....
Post by marco_polo » Fri Jun 09, 2017 11:25 am
Here you go, quite different to the fat-ring lower halves:
I've not looked closely at the clearances between SF and chassis rails, but I'd be surprised if that altered the height much, if at all.
Blind Pugh
Post by Blind Pugh » Fri Jun 09, 2017 12:25 pm
MP - thanks and you are probably right - the profile of these doesn't look like it will create any upstand as far as OEM contact surfaces between chassis rails and rear s/frame. Thanks again, BP.
AW M2 DCT
Post by marco_polo » Sat Jun 24, 2017 1:55 pm
Couldn't take the harshness any longer! This Black shore has zero 'give' in it, tougher than a granny's fanny. I've carefully cut the ring off as you can see, hoping to retain the lateral stability whilst losing the vertical 'twang' I've been suffering.
Road testing to follow (after Baku Quali has finished).
EDIT: Rides better now - as an initial reaction, watch this space for some more feedback later in the week following some motorway testing.
Post by marco_polo » Mon Jun 26, 2017 2:14 pm
Yup, that's done the trick. 90% of the harshness when hitting cats-eyes / expansion gaps has gone, but the rear end is still nice and stable.
Happy with that. :)
git-r2
Post by git-r2 » Mon Jun 26, 2017 2:25 pm
"Tougher than a granny's fanny"
:lol: :lol: :lol: :lol: :lol:
Just read the whole thread...
Great stuff!!!! - thank you for sharing your experiences!!!!
Couple of q's:
What camber are you now at?
What power have you been runnning and for how long?
Fancy a south London meet up?? Preferably without cars and with beer :)
Sam
'13 M135i standard.. and will remain so.. I promise... really.. will not modify... or abuse on track..
'91 R32 GTR... basically standard and unmolested... 497 @ rear hubs... never raced nor rallied : https://youtu.be/jhsX0elVG2k
+ some dullness
