Stevo's M140i
ratedrkstevo
Re: Stevo's M140i
Post by ratedrkstevo » Sat Aug 19, 2017 3:16 pm
2016 M140i
JB4
Motech/Eibach lowering springs
15mm spacers front and rear
Maxton kit
Custom backbox delete
ratedrkstevo
Re: Stevo's M140i
https://instagram.com/p/BXqV49zhu1P/
2016 M140i
JB4
Maxton kit
ratedrkstevo
Re: Stevo's M140i
Post by ratedrkstevo » Sat Aug 19, 2017 3:18 pm
2016 M140i
JB4
Maxton kit
D6EML
Re: Stevo's M140i
Post by D6EML » Sat Aug 19, 2017 4:33 pm
2016 M140i
JB4
Maxton kit
Thoughts on the intake ? Much noise ?
Dean
M140i / SB / AUTO / 15mm HR / CARBON SPOILER / MAXTON KIT / AUTOID CAPS / M4 COMP REPS
Nik_nak
Re: Stevo's M140i
Post by Nik_nak » Sat Aug 19, 2017 6:44 pm
You car sir is spot on.
ratedrkstevo
Re: Stevo's M140i
Post by ratedrkstevo » Sat Aug 19, 2017 7:53 pm
D6EML wrote:
2016 M140i
JB4
Maxton kit
Dean
Noise is nice but my exhaust noise drowns it out quite a lot. Makes the car a bit lumpy at low speed but in map 3 at higher speed it seems to have a positive effect. Would love an Agency power one to try out and compare.
2016 M140i
JB4
Maxton kit
ratedrkstevo
Re: Stevo's M140i
Post by ratedrkstevo » Sat Aug 19, 2017 7:54 pm
Nik_nak wrote:You car sir is spot on.
Thank you very much for your kind comment. Spent so much time, research and money on the car... really appreciate it Image
2016 M140i
JB4
Maxton kit
Wolfgang
Re: Stevo's M140i
Post by Wolfgang » Sun Aug 20, 2017 9:28 am
Literally ticks every box for me, good job
ratedrkstevo
Re: Stevo's M140i
Post by ratedrkstevo » Sun Aug 20, 2017 9:35 am
Wolfgang wrote:Literally ticks every box for me, good job Image
Thanks Image
2016 M140i
JB4
Maxton kit
D6EML
Re: Stevo's M140i
Post by D6EML » Thu Aug 24, 2017 8:42 pm
D6EML wrote:
2016 M140i
JB4
Maxton kit
Dean
2016 M140i
JB4
Maxton kit
Stevo did you fit the intake yourself ? What's involved ? I've got a bms sitting here waiting to go on
Dean
ratedrkstevo
Re: Stevo's M140i
Post by ratedrkstevo » Thu Aug 24, 2017 8:47 pm
D6EML wrote:
Dean
2016 M140i
JB4
Maxton kit
Dean
Yes fitted it myself. Pop the top of the box off and remove the filter. Undo the torx screw to the left and use that to fit the BMS fitting - you can also pop a socket on if you don't have torx. Unscrew the sensor off the standard airbox and attach to the BMS. Pop the intake on. Takes five mins and is super easy.
I highly recommend popping the driver side grill and taking the little cover off that's on the left hand side. Made a difference for me.
2016 M140i
JB4
Maxton kit
D6EML
Re: Stevo's M140i
Post by D6EML » Thu Aug 24, 2017 8:53 pm
Nice one mate il manage that , does the cover behind the grill just pull of or need cutting ? Take it more airflow to the filter with ye cover removed ?
ratedrkstevo
Re: Stevo's M140i
Post by ratedrkstevo » Thu Aug 24, 2017 8:55 pm
D6EML wrote:Nice one mate il manage that , does the cover behind the grill just pull of or need cutting ? Take it more airflow to the filter with ye cover removed ?
It just unclips, increases airflow and although you wouldn't think it would do much, I've found it certainly has a positive effect
2016 M140i
JB4
Maxton kit
D6EML
Re: Stevo's M140i
Post by D6EML » Thu Aug 24, 2017 8:56 pm
Super thanks mate
2016 M140i
JB4
Maxton kit
D6EML
Re: Stevo's M140i
Post by D6EML » Tue Aug 29, 2017 4:41 pm
Super thanks mate
2016 M140i
JB4
Maxton kit
Popped the intake on today , simple enough , did you angle yours down slightly into the air box ? Looks a little deeper in the box than mine
Dean
