e93 2007 325i adding bluetooth to CCC unit
All other aftermarket mods
Moderators: Producethis, Lambster, babybmwadmin, Rich196, marco_polo
Post by F1KAV » Fri Jan 19, 2018 12:07 pm
Hello experts and hobbyists, I'm hitting so many dead ends trying to work out how to do this..
please can I have some help on what I need and what I need to do to get Bluetooth in my car...see photo:
I have no harness or modules in boot.
a seller on Ebay says this will fit? https://www.ebay.co.uk/itm/BMW-E92-Prof ... Ciid%253A1
with this comment:
Yes, the unit is compatible. I'm not 100% sure on location as it's slightly different for the convertible but it will definitely work. There's obviously some wiring to route and a couple of connections to make (labelled on the harness), so just be aware of that. You MAY need to have some coding done to enable it on the car (I say may as you have the sat nav, which I've not got loads of experience with. It won't need coding on a car without sat nav).
