WANTED Bmwp exhaust e87 130i
All other aftermarket mods
tttc
Re: WANTED Bmwp exhaust e87 130i
Post by tttc » Mon Jan 29, 2018 7:37 pm
https://youtu.be/-9eSFM4fRQA
Scorp
Post by Scorp » Mon Jan 29, 2018 10:20 pm
That...sounds nice..
Whats he done top make it like this?
markhurley
Post by markhurley » Tue Jan 30, 2018 6:29 am
I’ve booked my car in for exhaust surgery I will update once done .. will be towards the end of feb
jonwilli
Post by jonwilli » Tue Jan 30, 2018 6:49 am
Modified 135i back box with some chrome exhaust tips welded on would be the cheapest way to look OEM and get a bit more noise than BMWP box. I think BMW even sell slide on chrome exhaust tips for the 3 series that could be used.
E81 BMW 130i
tttc
Post by tttc » Tue Jan 30, 2018 7:58 am
I think the 135 backbox plus Y pipe is the way to go for less spend, but seems to require some fabrication in that the hangers on the 135 box need moving and some custom pipe work to connect the mid pipes to the back. I need to do more research and learn what this actually means though :)
Fritz
Post by Fritz » Tue Jan 30, 2018 11:22 am
I'd also be very interested to see an opened 130i backbox. I currently have a spare system that I'm considering doing this to, the quote to weld it back up was £50-£60
Poormans
Post by Poormans » Tue Jan 30, 2018 7:47 pm
There are pictures about of cut x30i boxes. Makes it look like there are only subtle internal differences with stock. Also drove a 130i years back with a PPI and PPE. But in retrospect, the mid box was probably also removed. Sounded glorious, like a m3 3.0.. loudness was around 7.5 to 8. On a scale where 10 is taking the p*ss and golf T mod is aprox a 6.
Would love to manual the flapper too. Always shut/stock/always open.
shooting brake
supercati
Post by supercati » Wed Jan 31, 2018 7:47 am
You can do that! :)
I will do it soon to mine, I will try to do a DIY. It's like a 20€ mod, very easy. 12V relay on the trunk, and you're able to close or open it with a remote controller :D .
0l0dom0l0
Post by 0l0dom0l0 » Wed Jan 31, 2018 1:36 pm
Did a lot of research into this.
BMWP sounds great, but the change from stock in terms of volume isn't much. At cold starts it's pretty throaty and howls at the top end but overall in the cabin I'd say it's underwhelming.
Biggest area of restriction (for sound) is the mid box. You need to delete that get any more substantial volume. I have deleted mine and run it with the BMWP backbox which really brings it alive.
I've currently got a leak under the car due to the poor fabrication of the pipe so am looking to order the bastuck mod pipe from germany for £150 that deletes the centre resonator and bolt that up to my BMWP backbox.
Also for reference the BMWP backbox is already straight through on the flap control side of the exhaust.
If doing it again I would go 135 backbox and centre resonator delete and save the money over the BMWP backbox.
B12 KIT with M3 LCA and TS.
tttc
Post by tttc » Wed Jan 31, 2018 1:38 pm
Does mid box delete give any MOT/emissions issues? or is it purely there for sound reduction?
0l0dom0l0
Post by 0l0dom0l0 » Wed Jan 31, 2018 2:18 pm
I'm about to find out as mine is going in on Saturday.
There won't be any emissions issues though, it's not a catalyst.
Fritz
Post by Fritz » Wed Jan 31, 2018 2:34 pm
Thought I read somewhere in a post from Marco that a car has to have the right number of resonator boxes to pass the mot
JayBee89
Post by JayBee89 » Wed Jan 31, 2018 5:10 pm
My 2010 125i is running a Y pipe with a standard back box and it flew through its MOT at BMW last year.
2010 Alpineweiss 125i E82 M Sport | Dare DR-RS 18", Eibach Pro Street S, Darklines | Thread: viewtopic.php?f=19&t=85931 |
Fritz
Post by Fritz » Wed Jan 31, 2018 5:19 pm
Is there any droning with your system?
JayBee89
Post by JayBee89 » Thu Feb 01, 2018 1:20 pm
There is a little, tends to be around 2000rpm but apart from that it's fine. Mine's been done for about a year now so I'm used to it. I'd highly recommend getting it done if you're on the fence. It sounds great with the y pipe!
