New Release! SPL Front Lower Control Arms F8X M2 M3 M4- Street Version
All other aftermarket mods
Blind Pugh
Post by Blind Pugh » Fri Feb 09, 2018 9:24 am
F87 (& F2X) adjustable front LCA's by SPL incl xenon regulator rod
More info here
Matching SPL adjustable Tension Struts - details here
AW M2 DCT
GeoffCollins
Re: New Release! SPL Front Lower Control Arms F8X M2 M3 M4- Street Version
Post by GeoffCollins » Fri Feb 09, 2018 10:59 am
More info here
Do you think these will these fit on the 2014 M135i, without having to make spacers?
M135i (2014 Manual) - Custom Stainless Exhaust, JB4, BMS Intake, M4 LCA, Eibach Pro's, Cades Bern Wheels, Reiger Diffuser, Maxton Splitter, Double Slat Grills, M4 Mirror Caps
Blind Pugh
Post by Blind Pugh » Fri Feb 09, 2018 11:57 am
Geoff,
SPL LCAs - no spacers required should be PnP.
SPL TS - F8x TS likely still to require spacers for F2x /F3x applications - perhaps you could ask SPL directly as they might make sets of F2X/F3x specific TS's ie PnP and no spacers/packers required.
Also - looking at the details/adjusters - not sure how resilient these will be re wintery conditions and salted/gritted roads. Solid mounts at both ends likely to increase NVH. Perhaps more so than camber plates.....
BP
AW M2 DCT
GeoffCollins
Post by GeoffCollins » Fri Feb 09, 2018 2:27 pm
Geoff,
BP
Thank you, will give them an email now :)
markhurley
Post by markhurley » Fri Feb 09, 2018 7:45 pm
They look like they might be a bit hardcore for the rd , perfect for the track tho
