My Suspension quest! 130i
All other aftermarket mods
THETYRANT
Re: My Suspension quest!
Post by THETYRANT » Tue Nov 24, 2015 5:11 pm
Mark34bn wrote:I really like the look of the TC Kline shocks. Basically modified Koni sport units with a shorter body and top adjustable too. Shame they're £80 more each but probably worth it.
Not sure if import taxes etc would push the price up even more though.
I did toy with the idea of those as well, but i didnt want to go up on spring rate which they recommend and are valved to suit, maybe the lowest spring they do (400lb) might be ok on road though, i would want front and rear with springs etc though and it was going to be more than i can get Ohlins for so deceided to go stock Koni again for now.
Mark34bn
Post by Mark34bn » Tue Nov 24, 2015 5:32 pm
Ahh I see - I thought those rears were just Koni's but shorter.
That's the trouble with looking at the American forums, I'm not familiar with the brands and usually get half the info!
I'll put the zipties back on for a few days then take a measurement to see how much extra travel is used. Another option if space is really tight could be the Dinan top mounts -
http://www.dinancars.com/product/d110-0 ... 08-2013-2/
Current : Renaultsport Megane R26, Ford Kuga Titanium X
Previous:130i M Sport, E46 330d M Sport Touring, E36 328i Sport ,E36 M3, Sierra XR4x4 TT280
THETYRANT
Post by THETYRANT » Tue Nov 24, 2015 5:48 pm
Yeah the rears are modified to allow incar adjustment and they revalve to suit springs supplied, fronts they really go to town on and again revalved to their specs but also threaded to take aftermarket coilover spings and make them height adjustable, nice setup I think but pricey due to all the work that goes into them, on rears they supply height adjusters for rears as well, see link - http://www.tcklineracing.com/webdocs/It ... ils978.cfm" onclick="window.open(this.href);return false;
I think the Dinan rear mounts are only required if going mega low, as you've found a little off the bumpstops makes plenty of travel for normal ride height cars :D
markhurley
Post by markhurley » Tue Nov 24, 2015 5:57 pm
Could i not just cut the old bump stops off my existing sleeves and glue the birds ones on ? the rear m sport springs on mine were D2's and the rear damper part number is 33526771559
deelite
Post by deelite » Tue Nov 24, 2015 6:26 pm
Interesting stuff again :)
Here's a good review of Bilstein B6 & B6 a10:
http://www.m3forum.net/m3forum/showthread.php?t=506953" onclick="window.open(this.href);return false;
http://www.m3forum.net/m3forum/showthre ... 953&page=4" onclick="window.open(this.href);return false;
There seem to be limited suspension travel with B6 in front compared with koni yellow, this can be compensated with GC camber plates or cutting the bump stops:
http://www.m3forum.net/m3forum/showthread.php?t=497497" onclick="window.open(this.href);return false;
Could this be the reason why the Birds suspension feels harder in the front too?
BMW E81 130i M Edition Sport 10/2011 manual BMWP intake Black Sapphire M 261 Ferric Gray Michelin PSS
markhurley
Post by markhurley » Tue Nov 24, 2015 6:40 pm
deelite wrote:Interesting stuff again :)
Can the internal bumpstop be changed or is this a factory only job ?
Some good links there i love reading through all this stuff proper interests me :D
deelite
Post by deelite » Tue Nov 24, 2015 6:47 pm
It can be changed :)
Here's a video, opening the B6:
http://forums.m3cutters.co.uk/showthrea ... 709&page=2" onclick="window.open(this.href);return false;
THETYRANT
Post by THETYRANT » Tue Nov 24, 2015 7:25 pm
Yes ive read all those and been chatting with Dal quite a bit over on M3cutters, he has nearly as bad a suspension swapping disease as me :lol:
As you've found internal bumpstop on the inverted dampers can easily be trimmed, its just a question of how much is safe I guess, I felt the Birds fronts could of done with a tweak myself as there isn't a huge amount of travel before contact starts, i know Kevin at birds said they get Bilstein uk to do some tweaks once dampers arrived from Gemrany and i suspect that tweak the bumps might be what they do, i have no proof though its just an idea.
Ian
THETYRANT
Post by THETYRANT » Tue Nov 24, 2015 7:31 pm
markhurley wrote:Could i not just cut the old bump stops off my existing sleeves and glue the birds ones on ? the rear m sport springs on mine were D2's and the rear damper part number is 33526771559
Sleeves pull off the oem bumpstops easy enough but the birds bumpstop is a little smaller OD so wont hold the oem sleeve on, you could use cable ties to hang it from the cup washer at the top, i have actually done this on one side as my modified bumpstop first bonding didn't hold 2 parts together and sleeve fell down, will get a picture when im next under there.
THETYRANT
Post by THETYRANT » Tue Nov 24, 2015 7:57 pm
Here is a picture i found on my phone earlier (well 2 pictures spliced together), it shows the difference in rear bumpstop lengths with OEM (from a E82 which was same length as my E87 but slightly different nose shape) as longest in middle, Birds B1 on the left and my modded E87 short one on the right.
THETYRANT
Post by THETYRANT » Tue Nov 24, 2015 7:59 pm
duplicate post :oops:
deelite
Post by deelite » Tue Nov 24, 2015 8:32 pm
Ian
You're right Ian, the question is how much to cut. In that aspect the GC plates might be a better option, there's 7/8 '' extra suspension travel, possibillty adjusting camber and the bump stop retains its full lenght and progression, but it costs extra cash :D
Marc
deelite
Post by deelite » Tue Nov 24, 2015 10:11 pm
Here's a fierce debate about Dinan mounts :) :
http://www.e90post.com/forums/showthread.php?t=1024256" onclick="window.open(this.href);return false;
Another option is the Bmw E90 poor road package, these 10mm spacers are fixed between the springs and the car body, but they raise the car also 10mm.
Part nr 3 front:
http://bmwfans.info/parts-catalog/E90/E ... ing_parts/" onclick="window.open(this.href);return false;
Part nr 10 rear:
*123D*
Post by *123D* » Tue Nov 24, 2015 10:51 pm
deelite wrote:It can be changed :)
Really nice links deelite
123D is a diesel with two turbos :lol:
deelite
Post by deelite » Tue Nov 24, 2015 11:40 pm
THETYRANT wrote:Here is a picture i found on my phone earlier (well 2 pictures spliced together), it shows the difference in rear bumpstop lengths with OEM (from a E82 which was same length as my E87 but slightly different nose shape) as longest in middle, Birds B1 on the left and my modded E87 short one on the right.
Nice pics, they show a clear comparison. The Bmw seems to be progressive, the Birds bilstein linear.
