E81 130i Rear Shock Absorber
1K views 0 replies 1 participant last post by  MPN1
I recently bought a 130i le m sport and will need to replace the rear shock absorbers at some point.
Is this relatively straight forward ?
I was going to use Bilstein B6 shock absorbers and replace the mounts and bump stops at the same time with Powerflex.
The top mount seems straight forward to buy and replace but I'm not sure which one I need for the bottom, could anyone help please ?
Also is the bottom mount straight forward to replace or will I need a bush puller ?
Any advice would be greatly appreciated.
Thank you,
Mark.
