Hi,
For some unexplained reason I have some screws missing from the passenger-side trim under the glove box, which makes the trim hang down. It seems I need 3 standard screws to fix it all back.
Having looked on eBay, Amazon and Google, I can't find the screws I need. Can someone let me know what they are called, or where to find them?
The head is torx 20, the length is around 20mm from head to tip and 4mm wide and has a semi-loose washer.
