Does anyone have a how to for front pads?
rydale13
Post by rydale13 » Mon Nov 06, 2017 8:36 pm
Hi guys,
I'm searching high and low and I'm struggling to find a decent how to for changing front brake pads and sensor.
M135i.
If anyone could point me in the right direction, or give me a few tips, I'd massively appreciate it.
Thanks in advance.
Re: Does anyone have a how to for front pads?
Post by marco_polo » Mon Nov 06, 2017 9:03 pm
This is really simple, the trickiest bit is getting the wheel off.
Wheel off
Hammer 2 pins backwards (catch the spring clip, noting it's orientation). Try not to damage the nice blue paint!
Gently slide caliper pistons all the way back (use a lever between old pad's friction face and disc if necessary)
Remove pads.
Refitting is the opposite of removal.
One pad will have a wear sensor cable. Remove the old cable completely, noting the routing as you unclip it all the way back to the connection box.
Once done, into the service menu and reset the CBS for the front brakes only. Too easy. :)
Post by marco_polo » Mon Nov 06, 2017 9:08 pm
This guy makes a bit of a meal of it, it genuinely shouldn't take as long as 2 minutes.
rydale13
Post by rydale13 » Mon Nov 06, 2017 9:12 pm
Nice one, Marco.
Thanks for taking the time to explain.
Few questions...
Hammer pins backwards, I assume you mean hammer pins from the rear of the caliper to get the pins to protrude from the front of the caliper?
Also you mentioned a spring. Now you've said that, I immediately think of the tricky scalextric springs that fly off never to be seen again!?
Cheers.
Post by marco_polo » Mon Nov 06, 2017 9:14 pm
Nope, pins hammer back towards the engine. Out the back.. Backwards....
Maybe watch the video ^ :P A video is worth a thousand words.
rydale13
Post by rydale13 » Mon Nov 06, 2017 9:15 pm
Replied before watching that video.
Thanks for sharing that.
You weren't exaggerating!
It's easier than changing a newborn's arse.
Something to get done this weekend, then.
Cheers!
rydale13
Post by rydale13 » Mon Nov 06, 2017 9:19 pm
I've just upgraded to RBF600 fluid.
Can't properly see the benefit until I've fitted the new front pads.
There was a small window of improvement, but I think the pads have had it!
Really struggled to find any replacement pads that weren't either extortionate (m4 sport pad for example) or had too many mixed opinions (yellow stuff).
Decided to stick with stock pads. Hoping the fluid will have made a big enough difference to keep me happy.
Post by marco_polo » Mon Nov 06, 2017 9:31 pm
I'm going M4 front pads next time around.
I was on Carbotech XP8's which were awesome on track, but just a little to hot for pottering around town - squeally when cold/glazed.
rydale13
Post by rydale13 » Tue Nov 14, 2017 9:26 pm
FYI - for anyone looking to tackle their own pads for the first time.
I've since decided to invest in one of these from eBay.
https://m.ebay.co.uk/itm/18pc-1-5mm-to- ... mwBanner=1
Should hopefully make removing the caliper pins much easier next time as the pins were right tw*ts to remove.
Also there's something cringeworthy about hammering the arse of a screwdriver to shift the pins out...
T26TGT
Post by T26TGT » Mon Apr 30, 2018 11:38 am
Anyone know the correct orientation to the brake pads - I seem to be having some wired noises after installing new brake pads. Sounds as if they are loose.
Current Cars: F22 Alpine White M235i and F20 LCI Alpine White 120d M Sport
Past Cars: R55 Mini Clubman, Renault Clio 182 (Track Spec), E81 118d M Sport, Peugeot 207, MG ZR, Renault Clio RT, F20 118d M Sport
Return to “How To's”
