Basically went through a car wash about a year back and it took it managed to break off the aerial somehow. Looking to replace with a shark fin. I've got one, but replacement wise what should I do?
I seem to have found access but requires me detach the roof lining to access the bottom where it screws in?
There was two plastic screws holding the lining to the roof, then the llining kinda tucks into the rubber boot seal? Is this likely to damage the lining? Or can I remove the base from the top carefully with a scalpel if it's just glued on or?
Big thanks!
Big thanks!
