List of all How To's documents in PDF format
Moderators: Producethis, Lambster, babybmwadmin, Rich196, marco_polo
Site Administrator
Site Administrator
Post by babybmwadmin » Sat Sep 12, 2009 11:05 pm
Folks, you wont be able to add to this post, but its a work in progress.
This section of the forum will gradually get smaller as I move all the How To's into the below, in PDF format.
This will make it easier for people who use the How To's - they can down load a copy or print it off and use it without the need of having the forum open beside you
Should you have any questions about the How To guides, please send a PM or email to the person mentioned at the top of the guide - it says "Courtesy of xxxxx"
Please note that all these files are in PDF format.
If you do not have a PDF reader, you can get a free one from Adobe
How To: access the hidden obc functions
How To: bluetooth pair a se t630
How To: create audio cd's for your 1 series
How To: getting petrol station icons on Sat Nav map
How To: remove the door panel
How To: install a Tunit box
How To: install a handsfree kit
How To: reset the MPG indicator
How To: install a Dragon Tuning box
How To: reset tyre pressure system (TPS) warning light
How To: convert a non multi function wheel to multi function
How To: Remove Front Ceiling Light
How To: Turn off DTC and stability completely
How To: Add a speed camera POI to your SatNav DVD
How To: Remove the Centre Vents
How To: Upgrade the standard speaker setup
How To: Disguise stone chips
How To: Install a Garmin Nuvi
How To: Remove badge letters on rear
How To: Install a Shark Fin Aerial
How To: Reset service indicators
How To: Add xenon white angel eyes
How To: Fit a Strut Brace
How To: Adjust xenons for driving in europe
How To: Install a flip up dash Sat Nav system Warning: Large file - 9.2mb
How To: Replacing the Automatic Gearshift Knob
How To: Changing the trim on a steering wheel
How To: Remove a door card
How To: Stop Squeaking doors and door rattles
How To: Install a shorter aerial/bee sting aerial
How To: Removing door panel - facelifted 120d M-Sport E81
How To: do an Instrument test
How To: Steering wheel removal
How To: Avoid Air bag & seat belt warning light
How To: access the rear speakers on a 5 Door
How To: Changing your brake pads - I
How To: Changing your brake pads – II (with pictures) Warning: Large file - 2.6mb
How To: Cure possible rear door squeaks
How To: Repair Rear Bumper Warning: Large file - 2.3mb
How To: Reset Service Lights and Brake Wear Sensors
How To: Install LED numberplate lights
How To: remove and refit sill finishers
How To: Add a OEM SIRIUS tuner to 135i Warning: Large file - 4.3mb
How To: Upgrade standard seats to M-sport’s with bolsters
How To: strip & repair windscreen washers Warning: Large file - 2.2mb
How To: fit a BMW Short Shift lever
How To: Fit a Towbar & Electrics
How To: Cut the engine whilst in motion in an emergency
How To: drive without your key inserted
How To: Adjust Xenon Lights for Driving Abroad
How To: remove a dent using Ding King Kit
How To: Recalibrate OBC MPG calculation
How To: Remove/replace rear seats
How To: Refurbish a BMW remote control
How to: Retrofit footwell illumination
How to: Glasses Case mod
How to: Build a Fibre glass Sub Box
How to: Change your microfilter
How to: Check which service is required next
How to: Debadge
How to: DIY fitting Dash Storage Compartment
How to: EGR restrictor
How to: Fitting an Armrest
How to: Fix your Rear Parking Sensors when pushed in
How to: Front bumper angel eyes HIDs
How to: Golf Tee Mod
How to: Install your own BMW Performance Steering Wheel
How to: Make and install ram air scoops
How to: Remove dome light module
How to: Remove unsightly trim crease mark from gear gaitor
How to: Replace round BMW boot emblem Hatchback
How to: Replacing Bonnet Alarm Sensor
How to: Reset service light
How to: Route satnav wires through the dash
How to: Tint windows
How to: Upgrade to double nozzle rear wiper
How to: Fix the fuel tank trim/flap that will not close properly (E87 Fuel Pot Spring Failure & Replacement)
Return to “How To's”
