Heres a fix that solved my problem.
1. Get a teflon/grease spray..I use this from MOTIP.
2. From this picture you can see the inside of the armrest, goes out over the round part, that can be rotated (hard to explain). It's from inside of this point, that the squeaks "are living"
3. Close the armrest, and put the spray tube at the indicated arrows, and give it a good blast. This will push the grease inside, and make a nice film, where theres contact between the plastic...... And now, no more noise or squaks!
