Cruise control retrofit
Wibbles
Re: RE: Cruise control retrofit
Post by Wibbles » Fri Aug 12, 2016 10:51 am
Twenny wrote:
Wibbles wrote:DCAN cable from http://www.cable-shack.co.uk
This one ok Wibs?
https://www.ebay.co.uk/itm/262131709998
I only recommended those cableshack cables as I know they work and Jimmy give great customer service.
BRD on Facebook
THETYRANT
Re: Cruise control retrofit
Post by THETYRANT » Sun Aug 14, 2016 6:48 pm
Been doing this retro fit today on my 135i, got stalk unit and cowl swapped over no problems but have run into issues coding, i think its my ancient laptop causing unstable connection, i was able to add option $540 to cas and write it but had issues with frm part although did get it to do it in the end, however was not happy laptop/cable was stable enough to start doing other modules and dont want to brick anything so called it a day! , job for wibbles now i think to finish it off :)
Suprisingly the cruise does work fine even not fully coded, just i have the warning lights on for dsc etc to sort.
ian
THETYRANT
Post by THETYRANT » Mon Aug 15, 2016 7:28 pm
Got my coding finished off today and now cruise and everything else is working tiptop with no errors, big thanks to Wibbles for the fine tuning tips :D
For those thinking of doing it the diy was helpful but there are some tweaks/improvements to streamline things a bit more, most of it is in this thread somewhere so read it right through, things like only coding relevant modules (DSC and Kombi) not whole car after you have added correct option to the VO, also using tool32 for steering wheel calibration is much easier than DIS which I couldn't get going.
Ian
Post by Twenny » Mon Aug 15, 2016 7:34 pm
I'll be contacting Wibs soon to code mine me thinks lol
Lankan
Post by Lankan » Sun Sep 04, 2016 12:02 am
Thanks OP! Managed to fit/code myself with your help.
alpinweißE82 123d Coral Red Leathers
New to the family:
E87 118d 2009 N47 Engine (Odometer - 100,000+)
I've coded: Cruise control retrofitted, Digital speed, Beep, DVD in motion
I do regular trips from Newcastle to London message me for more info...
Willz135
Post by Willz135 » Tue Sep 13, 2016 1:29 pm
Hi guys,
So I recently bought a kit from a forum member and have fitted the bits to the car.
The cruise control works but I have error lights on my dash :( the issue is caused by, see images below:
Can anyone shed any light on this?
Cheers guys
Will
2008 N54 135i Carbon Black with BMWP Exhaust, Wheels, Body Kit, Gearstick, Short-Shift, & Pedals
THETYRANT
Post by THETYRANT » Tue Sep 13, 2016 1:44 pm
Willz135 wrote:Hi guys,
Cheers guys
Will
Have you coded the CC option to DSC and Kombi ? as well as reset steering angle sensor, if not then that is why you have errors on dashboard.
Willz135
Post by Willz135 » Tue Sep 13, 2016 1:51 pm
Cheers guys
Will
Hi mate, thanks for the response.
No we haven't because for some reason it won't let us code it. We are using NCS to code but also have DCAN, but sounds like the same issues you were having!
Will
THETYRANT
Post by THETYRANT » Tue Sep 13, 2016 2:23 pm
I was having communications issue with cable/software which turned our was down to the USB port settings within windows (thanks Wibbles for helping with that :) ) , is this problem you have when trying to code or read modules ?
Willz135
Post by Willz135 » Tue Sep 13, 2016 2:33 pm
THETYRANT wrote:I was having communications issue with cable/software which turned our was down to the USB port settings within windows (thanks Wibbles for helping with that :) ) , is this problem you have when trying to code or read modules ?
We can actually communicate, but the DSC lights are left on. We can't seem to get rid of the traction control lights.
Will
Willz135
Post by Willz135 » Tue Sep 13, 2016 2:44 pm
Guys, we have finally sorted it and it seems to work fine with a bit of patience :)
Happy a days cheers guys
Will
THETYRANT
Post by THETYRANT » Tue Sep 13, 2016 2:50 pm
Glad your sorted :) ive hardly used my cruise since fitting as i get better mpg driving manually on roads around here as there as so many hills!.. but on a long motorway run it is handy :D
Willz135
Post by Willz135 » Tue Sep 13, 2016 2:52 pm
THETYRANT wrote:Glad your sorted :) ive hardly used my cruise since fitting as i get better mpg driving manually on roads around here as there as so many hills!.. but on a long motorway run it is handy :D
I'm the opposite Image always on the motorway so I can't wait to use it haha.
Will
Biccus1
Post by Biccus1 » Wed Sep 28, 2016 7:46 pm
I would love to carry out this on my 1 series but I'm not good with computers and i would :censored: myself...
WHITE F20 2012 M SPORT,
Ash_M140i
Post by Ash_M140i » Mon Oct 31, 2016 12:26 am
Can this be fitted on an F21 M140i?
Return to “How To's”
