Replacing front wheel bearing
6K views 7 replies 8 participants last post by  Badley
#1 ·
#3 ·
They are quite expensive from BMW!
Thanks for posting the guide :)
#5 ·
Maybe the threadlock compound will let go if heated? A couple of minutes with a blow torch around the areas where the bolt ends are visible could help.
Spraying the relevant areas with a penetrating oil is also a good tip for this kind of work. And you should leave it for at least ten-fifteen minutes to let it work its way into the rusty htreads.
