How To Search This Forum
Post by marco_polo » Mon Apr 22, 2013 3:44 pm
As you might be aware, out in-built search fuction doesn't work very well. A common three letter search like 'EGR' or 'DPF' will return zero hits, and you can't search for more than 10 terms at once. :( But there is hope! Our lovely friends at Google will do all the hard graft for you, using the following terms.....
Into Google, type: site:babybmw.net followed by your search term/s EGR DPF . :)
Where Google falls over, is it will find search terms in peoples signatures as well as txt (which the in-built search won't). If this becomes a problem, try filtering your results with a negative term like -exhaust, so the overall search becomes: site:babybmw.net EGR DPF -exhaust
Hope that helps.
SteveM
Re: How To Search This Forum
Post by SteveM » Mon Apr 22, 2013 3:47 pm
Sticky request please.
Also a member of the YCHJCYA2PDTHFH club
tongy
Post by tongy » Mon Apr 22, 2013 4:03 pm
SteveM wrote:Sticky request please.
Agree, very useful post.
Manual M135i with M Performance exhaust
BigC
Post by BigC » Mon Apr 22, 2013 5:17 pm
+1
redwizard
Post by redwizard » Mon Apr 22, 2013 5:30 pm
+2
mods - BMWP power kit, black grills, LED darklines, Bimmian LEDs, pressed plates, light anthracite 222s
BMW OEM Retrofits - cruise, dynamic xenons, CIC pro-nav, DAB, combox, E91 sharkfin
sonicvanman
Post by sonicvanman » Mon Apr 22, 2013 5:48 pm
Be doing this for a while after your heads up on this some years ago.
I guessing your feed up of reply to everyone who post up about having search problems?
Return to “How To's”
