How to retrofit Bluetooth and USB - Finished!
ironman12345
Re: How to retrofit Bluetooth and USB - Finished!
Post by ironman12345 » Tue Jan 13, 2015 10:37 am
Hi do you know when you would be able to do it as could do with it asap
Wibbles
Post by Wibbles » Tue Jan 13, 2015 10:40 am
ironman12345 wrote:Hi do you know when you would be able to do it as could do with it asap
I don't know, sorry.
I have a pro nav retrofit to do on an E90 before I do anything else & I get very little time to myself as I have a small child to look after.
If you want it done quickly give Peter a call, he should be able to supply & fit everything & is highly recommended.
BRD on Facebook
ironman12345
Post by ironman12345 » Tue Jan 13, 2015 12:28 pm
Hi do you have a contact number for him also any idea where he based
Wibbles
Post by Wibbles » Tue Jan 13, 2015 1:09 pm
http://www.petervanderveer.co.uk" onclick="window.open(this.href);return false;
BRD on Facebook
simoncummings
Post by simoncummings » Sun Mar 15, 2015 9:36 am
Hi Rob,
Thanks for a great and informative post. I have a question which I don't think is covered...
I appear to be lucky enough to have a Pro HU with the Bluetooth built-in - a result!
What parts/steps to I need to get it working?
- Bluetooth Antenna
- Mic
- Coding
Is that it?
If you / or someone else on the forums would be so kind as to highlight exactly the components I need for my scenario, that'd be great - and much appreciated :)
2011 BMW 120d MSport Convertible
Space Grey / Red Leather.
Pro HU with DAB & BT and USB retrofit (still in progress!).
SteveBeech
Post by SteveBeech » Tue May 19, 2015 5:17 pm
Hi,
Could someone help please. I have 2010 1 Series with USB and DAB fitted. I have the mulf usb/Bluetooth fitted in boot.
I have fitted the mic (front light fitting connected to mulf) and the antenna.
I took the car to be coded but the garage did not really know what they were doing (ex BMW mechanics!). They upgraded the rest of my car but could not get Bluetooth going, They spent a lot of time trying to be fair, but this was new to them. Is there someone who could do the coding for me please. I live in the Oxford area.
Thanks in advance
Wibbles
Post by Wibbles » Tue May 19, 2015 8:17 pm
SteveBeech wrote:Hi,
Thanks in advance
If you have the MULF unit I can do it remotely. You will need a cable from http://www.cable-shack.co.uk" onclick="window.open(this.href);return false;
BRD on Facebook
SteveBeech
Post by SteveBeech » Wed May 20, 2015 4:05 pm
That's great wibbles. Is it the D-Can Switced cable or the D-Can Diagnostic set? Let me know and I will get one ordered. Please send me a PM to let me know how I can pay you.
Thank you for your help :)
Wibbles
Post by Wibbles » Wed May 20, 2015 4:09 pm
You need the D Can cable.
BRD on Facebook
SteveBeech
Post by SteveBeech » Wed May 20, 2015 4:50 pm
Thanks, I will order now
MichalS
Re: How to retrofit Bluetooth and USB - Work in progress!!
Post by MichalS » Fri Jan 01, 2016 5:17 pm
rob-the-viking wrote: Before you code this, if you've fitted a professional head unit, you will need to code this to the car first, the head unit acts as the MOST gateway, so to talk to the MULF in the boot over the fiber optic leads, the professional head unit MUST be coded correctly.
I've changed radio business to professional. When I try to code all modules i get error "mulf2 not found". That is probably because I did not code new radio to the car. How do I do this? Just add to VO? What is the option code for the radio prof? Anything else i need to do to be able to talk to the Mulf?
Michael
E82 '08 120D, Black Sapphire
Retrofitted: Prof. HU, MULF2 + USB + Bluetooth, PDC Front and Back, Logic 7, Xenon front, black lines back.
To Go: Electric Heated seats, 335D engine + exhaust + gearbox + diff, sport brakes and suspension.
Wibbles
Post by Wibbles » Fri Jan 01, 2016 5:25 pm
Remove $622 & add $633 to the VO
BRD on Facebook
MichalS
Post by MichalS » Sat Jan 02, 2016 10:20 am
There was no $662 radio business in the VO list.I added $663 - radio prof. RAD2 appeared. Still couldnt prgram 2ULF. "SG nicht angeschlosses oder meldet sich nicht".
Programmed RAD2 manually - Bluettoth_Rad2 Aktiv, ULF_ECE Aktiv. Bluettoth works. I can make calls. I did not check usb yet.
Seems like I cannot get NCS to program MULF2 via MOST connection.
Any ideas?
Wibbles
Post by Wibbles » Sat Jan 02, 2016 10:46 am
You cannot programed MULF with a normal DCAN cable, you need an ICOM but there is a trick. I'll post later when I'm available.
BRD on Facebook
Samy93
Post by Samy93 » Sat Jan 16, 2016 5:17 pm
I've read through this and the other Bluetooth/USB retrofit guides, and I'm not sure what head unit I have in my car still! The car is a 2010 e82 with professional navigation. The head unit looks like this
I don't have the USB under my armrest, and this is all I'd really want, is it as simple as getting the retrofit kit plugging into the (hopefully) optical connection on the back of the head unit and running to the arm rest with a new facia plate?
Thanks for any help guys!
Return to “How To's”
