Depo V1 Headlight Bi-Xenon Mod - UPDATED Page 1
aj_mckay
Re: Depo V1 Headlight Bi-Xenon Mod - UPDATED Page 1
Post by aj_mckay » Tue Aug 01, 2017 10:14 am
Ant_Smiggy120D wrote:
Twenny wrote:One of mine went about a year ago so you've done well to get this long out of them. It's time to buy yourself some halo rings mate and some butyl rubber sealant and change the rings yourself.
It's what I'm about to do soon.
This lasted less than a year mate. Just not been on here much myself tbh tried contacting Toby direct as I have his number and never heard back from him. Bit of a shame really.
Are the rings are standard size/ fitment? I don't really have the time to be messing about with them tbh flat out with work.
You'll have to let me know how you get on mate and document it. And what ring you use. If not I'll fire the standard lights back in with HID's and blind everyone with no projectors.
Give me a shout it you want rid of your depos. I'll take them as they are, subject to price.
'57 Le Mans Blue 120D E87 | Style 261s
WANTED: E8x headlights - all types required, please contact me if you're selling!
Sonic1506
Post by Sonic1506 » Tue Aug 01, 2017 10:22 am
Tue Aug 01, 2017 10:11 am
Mine didn't even last that long :lol: :lol: :lol: :lol:. He used cheap sh*t Chinese rings and silicone sealent to put them back together as well as other issues.
The rings are 95mm and 100mm.
I got another set made up by EM Tuning, using top end Morimoto parts and couldn't be happier. Give me a shout if you want more details.
Anish1993
Post by Anish1993 » Tue Aug 01, 2017 4:57 pm
I knew sonic would be around eventually lol i just knew.
I dont blame him for not having a warranty doe. He probably should have rehearsed it more clearly from the get go.
Sonic1506
Post by Sonic1506 » Wed Aug 02, 2017 12:15 pm
Mate. I been replying to this for ages.
If you're offering a service, you should also plan for potential problems. Toby didn't and neither to Headlight Retrofits.
Toby wanted payment for replacement parts and he wouldn't offer a refund on problematic lights.
Headlight Retrofits just used to bullshit about condensation and said some coating was the problem. They wanted £500 & old lights back to fix the issue by doing a new transplant. Again, refund would not be given.
At the end of the day, if YOU Are taking payment for a service and your service is not up to scratch you should either fix the problem OR refund the money. If you aren't going to offer this, then don't offer to make lights for people OR be clear from the start. Not half way down the line when problems occur.
Avoid BOTH on all accounts. Also avoid NEM, so called Europes best. Use a proper company/proper person.
Ant_Smiggy120D
Post by Ant_Smiggy120D » Wed Aug 02, 2017 12:18 pm
That would be brilliant mate. Think I'll have to chuck in my old lights and make time to have a go. Just time for me.
If you could let me know what rings I need to buy that would be a huge help. How are they fitted? Glued in? Appreciate the help
Ant
Sonic1506
Post by Sonic1506 » Wed Aug 02, 2017 12:41 pm
Ant
I'll send you a PM.
Post by Twenny » Sat Aug 12, 2017 2:18 pm
And so it begins Image
Got them both split and will finish them off at work. Updates to follow.
Ant_Smiggy120D
Post by Ant_Smiggy120D » Sat Aug 12, 2017 2:18 pm
Twenny wrote:And so it begins Image
Take plenty of pics mate
Post by Twenny » Sat Aug 12, 2017 2:24 pm
To be fair Ant if you follow Tobys how to at the beginning of this thread it's pretty easy.
Just need to find some decent/suitable glue to stick down the new rings and then something I don't know is, once the butyl sealant is re applied do I put them back in the oven to soften it up before sticking back together? I'm jumping the gun and will worry about that when I get to it lol
Ant_Smiggy120D
Post by Ant_Smiggy120D » Sat Aug 12, 2017 3:04 pm
Twenny wrote:To be fair Ant if you follow Tobys how to at the beginning of this thread it's pretty easy.
The rings compatible then? Wiring wise?
Post by Twenny » Sat Aug 12, 2017 4:02 pm
Compatible? I hope so, I bought the exact same ones as Toby fitted so not expecting any problems in that respect
Sonic1506
Post by Sonic1506 » Mon Aug 14, 2017 8:56 am
You can use Loctite Gel superglue. Sealent wise, you can use the Morimoto stuff or stuff from The Retrofit Source, their stuff goes in, then you clamp the headlight shut and that's it.
No heat is required.
Post by Twenny » Mon Aug 14, 2017 9:12 am
Hmm ok I may have to use this butyl rubber sealant as it's all over the headlight joins and is a PITA to get out of the grooves. Probably will have to put in oven to seal the joins but that's no problem.
Good idea with the glue sonic I shall purchase some asap.
aj_mckay
Post by aj_mckay » Mon Aug 14, 2017 9:16 am
I'd be reluctant to use super glue. Go for some two part epoxy resin, if anything. Alternatively secure the rings to the housing with fishing line - pretty much invisible when installed and won't melt like glue.
Butyl windscreen seal will be fine for re-sealing the lens to the housing.
Sonic1506
Post by Sonic1506 » Mon Aug 14, 2017 9:57 am
Make sure you get all the existing sealent out.
Fixing rings wise, as I recommended to you earlier in our PM's was using fishing line is another option but IIRC you said you can't get a hold of it?
Return to “How To's”
