Dash Storage and Nav Template
babybmwadmin
Site Administrator
Site Administrator
Post by babybmwadmin » Fri May 20, 2016 9:59 pm
All,
User Motley2012 provided me with a template for the E8x Dash Storage and Nav.
He states that it is just larger than A3.
If someone asked for the file to be printed on A3 the template would be too small.
It can be found here.
Obviously cutting up your dashboard is something you do at your own risk etc.
I suggest reaching out to him for further questions.
Motley2012, feel free to advise in this topic.
thanks
berne
Re: Dash Storage and Nav Template
Post by berne » Sat Aug 20, 2016 11:15 pm
nav template? how and what?
do any one know the measured of the hole?
BMW 135i M3 m3 LSD,Wagner Evo2 intercooler,Wagner 3" Catless Downpipes,N55 midpipes + Dinan axelback.,BMS Intake, Tial 50mm BOW
BMS modified clutch valve,BMS short shift kit,M3-Wishbones.M3-Control arms .M3-Control arms, NBT f30 and more:)
bulunge
Post by bulunge » Sat Jun 17, 2017 8:25 am
Hi,
Just a quick question:
Will this retrofit work in a pre LCI car?
Just want to be sure I'm not going to slice into anything unexpected when I take the tool to the dashboard.
Also, the retrofit kit comes with a bit of cabling, is that for a light? I assume there isn't a convenient connector just sitting there under the dash waiting to be plugged into... is there?
Bulunge -- 2005 120d Sport Auto --
Post by marco_polo » Sat Jun 17, 2017 8:38 am
Yes, this will work on a pre-LCI. No, there's not any kind of convenient connector sadly.
Post by Octavius » Sat Jun 17, 2017 8:59 am
The cables connects to the light in the glovebox. No cutting or splicing required. Just feed it through after removing the light fitting and it's plug and play.
Carsonalex336
Post by Carsonalex336 » Mon Aug 21, 2017 6:28 pm
Where do you buy the kit from please? Thanks
Return to “How To's”
