Valvetronic error code
riccie_120i
Post by riccie_120i » Sun Jun 17, 2018 11:15 am
Image here is of interest for two reasons.
a) wife captured car hitting 111,111 miles which is a bit of a rare occurrence(!)
b) at about the same point the dash error warning came up.
IMAGE >> https://drive.google.com/file/d/1EkfP-I ... sp=sharing
Continued journey for about 50 miles as car was running fine albeit with reduced power. RAC came and had a look yesterday (I don't have an OBD reader, but might actually get one now*) and read the fault as 'Valvetronic error'
All RAC did was erase the code and then we started the car and it continued running fine. Said it may be a glitch or may come back.
Car is due to go to garage for a general check over and oil change etc, which is due anyway, so I will report this error. I have read it could be valvetronic motor, valvetronic sensor, or perhaps the vanos solenoids.
RAC did not capture the code, but then again it is only a problem if it reoccurs.
Any ideas what is most likely are welcomed!
*recommendations welcomed
AP1
Re: Valvetronic error code
Post by AP1 » Sun Jun 17, 2018 2:30 pm
I guess you have a 120i. Fault will be due to: faulty valvetronic motor, faulty valvetronic sensor, oil on valvetronic sensor plug, worn valvetronic levers etc, stretched timing chain, slipped timing chain. It won’t take long for a specialist to diagnose. My guess is faulty motor.
riccie_120i
Post by riccie_120i » Sun Jun 17, 2018 6:12 pm
Thanks AP1
Yes, 120i. Just drove 80 miles and no recurrence of issue so suggests it is more like something intermittent. So perhaps the motor packing up a bit or an iffy sensor.
I'd expect something like timing to trigger the fault almost straight away if it was slipping/slipped, besides car ran crisp which is unlikely if timing was out.
thanks for the suggestions. as always once diagnosed I will post update for completeness.
riccie_120i
Post by riccie_120i » Thu Jun 21, 2018 10:16 am
motor was faulty. new valvetronic motor and fitting inc. computer setup required.
AP1
Post by AP1 » Thu Jun 21, 2018 10:57 am
Glad it’s sorted.
Return to “BMW Problems”
