CBS (Dashboard service lights) *at a glance*
DrRollo
Re: CBS (Dashboard service lights) *at a glance*
Post by DrRollo » Sun Jul 15, 2012 8:11 pm
But there is no specific service interval on it?
Post by marco_polo » Sun Jul 15, 2012 8:14 pm
Not that I'm aware of. The EGR body needs to cleaned out occasionally too, but it never features on any BMW service schedule. Nor gearbox/diff' oil changes.
DrRollo
Post by DrRollo » Sun Jul 15, 2012 9:50 pm
Ok i'll look up the EGR, planned to get gearbox and diff done at my next service.
Cheers again for the info.
f1racr
Post by f1racr » Mon Nov 26, 2012 7:54 am
I had a problem with rear brake pads running out so I replaced them but I've got the "Vehicle check" symbol still coming up and I dont' know how to reset it.
Is there a way to reset it now that I've replaced the pads ???
N52 Techie
Post by N52 Techie » Mon Nov 26, 2012 8:16 am
Emissions test CBS light is for china vehicles only, some cars it shows up on because the numpty who pdi'd it didn't deactivate it on the settings when deleting transport mode! It's for that same reason that mot doesn't show up on some vehicles. If you want these activated or deactivated it can be done at the dealer and takes 30mins maximum
Vikkimac1980
Post by Vikkimac1980 » Thu Jan 17, 2013 8:39 pm
I have just purchased a 1 series but it didn't come with a handbook, there is a little triangle that appears next to the mileage is this ok or anything to worry about?
Post by marco_polo » Thu Jan 17, 2013 8:50 pm
Hello and Welcome. :)
That usually means something fairly minor, like it's below 3°, you're a bit low on fuel, or a bit low low on washer fluid.
RichCranney
Post by RichCranney » Thu Jan 17, 2013 8:52 pm
Or a service is due
Lee_2f2f
Post by Lee_2f2f » Thu Jan 17, 2013 9:09 pm
marco_polo wrote:Hello and Welcome. :)
The warning does not stay there for that iirc?
I would scroll through you Obc until it says "check" and see what appears.
Gone: 09' 120d MSport, catched at 198bhp, Miltek, K&N, CSL Reps, BMWP parts, coding, & more.
Now: 05' E46 318ci Cabrio, dark Bloo, many options, and mods will come in time.
beefy_clyro
Post by beefy_clyro » Fri Jan 18, 2013 3:56 pm
I have the MOT light on, is there anyway I can turn that off as it has been MOT'd and still currently is?
CLICK HERE TO SEE FRANK
Post by marco_polo » Fri Jan 18, 2013 3:58 pm
beefy_clyro
Post by beefy_clyro » Fri Jan 18, 2013 5:00 pm
Thanks, don't know how I missed that! D'oh! Anyway, trick was, do it without starting the car ... sounds so obvious now ha
Stuey10
Post by Stuey10 » Sun Feb 24, 2013 3:46 pm
Hi. I have that vehicle check light come on sometimes when I switch my car on. It only comes on every so often and it resets all my clocks and mileage counters. Any ideas why this happens? It's a 118d MSport. Thanks
Stuart.
Post by marco_polo » Sun Feb 24, 2013 3:54 pm
Sounds like you've got a dying/dead car battery.
Is yours roughly a 2008?
Stuey10
Post by Stuey10 » Sun Feb 24, 2013 3:57 pm
Yes it is 2008. Cheers for the info il charge my battery over night and see if it stops it.
Cheers.
Return to “BMW Problems”
