Tyre Advice - RFT or NRFT ?
rob180bhp
Re: Tyre Advice - RFT or NRFT ?
Post by rob180bhp » Wed Jun 07, 2017 5:29 pm
marco_polo wrote:
rob180bhp wrote: โ†‘
Wed Jun 07, 2017 5:08 pm
What would be the recommended rear tyre size to match
Front 8.5j with 255/35/18
Rear 9.5j ????????
Sent from my SM-G928F using Tapatalk
You won't get much below a 35 profile, so nothing wider is going to match perfectly.
275/35/18 = +2.1%, which is just about acceptable (14mm bigger on diameter).
Thank you.. That was my guess as long I can find them In a decent brand I might try track semi slicks as the car is just a weekend toy now
E82 wide135i MHD stage 2/f30 brakes/meisterR/m3 everything / Vrsf
Instagram "rob180bhp"
Post by marco_polo » Wed Jun 07, 2017 5:33 pm
Toyo should be able to supply an R888 in 275/35
rob180bhp
Post by rob180bhp » Wed Jun 07, 2017 5:46 pm
marco_polo wrote:Toyo should be able to supply an R888 in 275/35
Toyo Ad08r or falken
All depends what matching set I find at the time
Danny_Boy
Post by Danny_Boy » Thu Jun 08, 2017 6:45 am
I have Pirelli P Zero's and cannot be happier. I couldn't stretch to the prices that Michelin want for their tyres, but the wet grip the Pirellis have is insane and dry grip is progressive.
2009 E82 135i Manual - MHD - Quaife Diff - BMWP Exhaust - VRSF DCI - Intercooler - Charge Pipe & Bov - Meister R's - M3 F&R Arms - Powerflex Bushes - Subframe inserts - AC S Type 3's - BMWP Strut Brace - Darklines - Spoiler
Red-Eye
Post by Red-Eye » Wed Jul 12, 2017 1:25 pm
Thanks for the reply's, going to take the plunge very soon as slicks/rain is not good !!
If I was to go with NRF tyres what do people use as a get me home on roadside fix ?
Another question, Do the insurance company need to be contacted to say that I'm switching from RFT to NRFT, I'm with Admiral on a multi-car policy ?
Post by Twenny » Thu Jul 13, 2017 11:12 pm
Tyre weld and 12V plug in inflator for punctures and yes inform insurance company or even call them first to ensure there's no premium rise.
Red-Eye
Post by Red-Eye » Fri Jul 14, 2017 10:41 am
Cheers for that, Have phoned insurance and they are happy with going NRFT without a premium rise :)
Any tyre inflator anyone could recommend and where to keep it as I've no room as battery is in the boot ?!
Post by marco_polo » Fri Jul 14, 2017 11:03 am
Have a look on eBay for Tyre Mobilty Kits. Any manufacturer (Kia, Ford, or whatever) will be fine.
Or just a big can (make sure it is the big one) of Holts Tyre Weld, or two.
Red-Eye
Post by Red-Eye » Sun Jul 16, 2017 7:50 pm
Right, I've taken the plunge MPS4 NRFT fitted ๐Ÿ‘๐Ÿผ
Next question is what pressures do people run them at ?
I have gone up a size, Front - 225/40/18(88) & Rear - 255/35/18(94)
Post by marco_polo » Sun Jul 16, 2017 8:57 pm
On a diseasil, I'd start with 35psi all round. Try that for a week, then fine tune to your liking.
stevesurrey
Post by stevesurrey » Mon Jul 17, 2017 12:38 am
Red-Eye wrote: โ†‘
Those front tyres really got a load index of 88 ?
Im not familiar with the PS4's but sounds a bit low for an XL tyre.
Red-Eye
Post by Red-Eye » Mon Jul 17, 2017 7:18 am
stevesurrey wrote: โ†‘
Red-Eye wrote: โ†‘
Your right, my fault the fronts should be 92 & not 88, rears are correct. Currently got 2.6 in front & 2.9 in rear but yet to drive anywhere until tomorrow.
stevesurrey
Post by stevesurrey » Mon Jul 17, 2017 8:31 am
Red-Eye wrote: โ†‘
Red-Eye wrote: โ†‘
Those pressures are rather high, especially the rears. unless u drive around with car fully loaded all the time.
Post by marco_polo » Mon Jul 17, 2017 8:35 am
I didn't spot that. Can you swap the fronts for 92 XL's?
If not, 35psi isn't going to cut it, probably too little pressure in a floppy tyre. :( Maybe start at 37 or 38 all round, and increase if you need to.
Red-Eye
Post by Red-Eye » Tue Jul 18, 2017 11:24 am
Is that 37-38psi on the fronts or all round ?
First drive today to work, much better ride on the bumpy roads but felt a bit understeary in the corners, might just be down to having softer wall tyres, or the fact that still got the sealant on the surface from manufacture, well see.
Return to โ€œTyres/Wheelsโ€
