Mak Luft-FF
kent dan
Mak Luft-FF
Post by kent dan » Fri Aug 18, 2017 3:59 pm
https://www.performancealloys.com/wheel ... load=False
What do you guys think of these?
18X8 ET43 for the front
18X9 ET44 for the back.
Fitment seems perfect for an F20 with LCA's.
These are flow formed so should be lightish and quite strong. I have never heard of them, has anyone ever had a set of MAK wheels?
Mineral Grey M140i. . Mini R53 weekend/track car
Lexus GH300h
Tuned M635csi back in 2017.
Re: Mak Luft-FF
Post by marco_polo » Fri Aug 18, 2017 4:43 pm
Proper fit, look good, nice and strong, what's not to like? :)
kent dan
Re: Mak Luft-FF
Post by kent dan » Sat Aug 26, 2017 7:03 pm
Damn can't get them in the fitment I'd like. 😠
Ah well think I will just go with some f30 rims, plenty on ebay.
Lexus GH300h
glen8
Re: Mak Luft-FF
Post by glen8 » Tue Aug 29, 2017 7:43 am
viewtopic.php?f=53&t=99263&p=1289351&hi ... t#p1284381
I have them, see page2 on the thread above
Fantastic alloy imho
kent dan
Re: Mak Luft-FF
Post by kent dan » Tue Aug 29, 2017 9:21 am
Looks good Glen, are they the flow-formed versions or the standard Luft?
Lexus GH300h
Blind Pugh
Re: Mak Luft-FF
Post by Blind Pugh » Tue Aug 29, 2017 9:36 am
8" et34mm work fine with M4 LCAs if running 225/40/18 MPSS
8" et43mm will also work fine with the above and should give you the option of running 245/35/18 upfront
9" et44mm is better with MPSS 255/35/18 IMHO than 245/35/18 as 9" gives too much stretch, effecting sidewall stability if you planning on driving the car as intended....
AW M2 DCT
sootyvrs
Re: Mak Luft-FF
Post by sootyvrs » Tue Aug 29, 2017 10:09 am
A member on here has these MAK Luft wheels in OEM width/offsets (7.5" ET45 & 8" ET52)
You can find the black ones here but you can also get silver ones
Fronts
http://www.ebay.co.uk/itm/6419361-ALLOY ... 1438.l2649
Rears
http://www.ebay.co.uk/itm/6419418-ALLOY ... 1438.l2649
2018 F87 BMW M2 DCT
2017 F21 BMW M140i Auto
2015 F56 Mini Cooper S Man
2013 F20 BMW M135i Auto
2010 R56 Mini Cooper D Man
2007 E87 BMW 130i Man
sootyvrs
Re: Mak Luft-FF
Post by sootyvrs » Tue Aug 29, 2017 10:16 am
Found some pics
glen8 wrote:
Tue Jun 13, 2017 4:43 pm
Got my new boots on
2018 F87 BMW M2 DCT
kent dan
Re: Mak Luft-FF
Post by kent dan » Tue Aug 29, 2017 10:29 am
I wanted to run 245/255 F/R but the wheels are not available at the moment, and can not say when they will be.
I think I will go your route and get some F30 alloys. 8Jx18 ET34 Fronts and 8.5Jx18 ET47 rears.
Much cheaper option to, as I can see quite a few sets on ebay for £4-500.
Do you think I could get 245's on the fronts, if I remove the lca's and get some camber plates instead.
Lexus GH300h
Blind Pugh
Re: Mak Luft-FF
Post by Blind Pugh » Tue Aug 29, 2017 10:49 am
Dan,
The F30 style FG 397's 18" 8"/8.5" off my car maybe surplus to my requirements - PM me if you are interested.
The issue with camber plates is NVH will increase although Vorslag [USA] and Millway [Sweden] do adjustable top mounts that are better than most.
If I'd kept my car, fitted with both F8x LCAs and matching tension struts, I think I would of given 245 MPSS a go on the front, as F8x TS centralise the wheel much more into the wheel so reducing risk of rubbing.
BP
AW M2 DCT
kent dan
Re: Mak Luft-FF
Post by kent dan » Tue Aug 29, 2017 11:00 am
Dan,
BP
BP,
Thanks for the offer, but I really fancy the 400m style wheel, I just think it would look really good on a 1'er.
I'll get a set and trial fit the 245's on the front and report my findings. Will probably have to get the F8x TS or roll the arches if they don't clear.
Thanks for all your advice.
Lexus GH300h
