space saver
Andykg
space saver
Post by Andykg » Fri Sep 01, 2017 10:21 am
im debating whether to ditch the run flats on the front and get normal then change the rears when they need it too. Trouble is I got 215/40/18 on the front and 245/35/18 on the rear so i cant just get a full size spare so will need to get a space saver instead. Im guessing a 16 or 17 space saver will work ok? ive only got a 2010 116D m sport LCI model so theres nothing different about brake sizes etc?? Can i run the space saver on the front or back in the event of a puncture? read a few places you can only run them on the back.
thanks
2010 116d m sport E87
Re: space saver
Post by marco_polo » Fri Sep 01, 2017 10:33 am
You could happily run a front wheel on the rear as a spare, if you wanted to. Putting a 215/40/18 back there temporarily would be far more stable than a 125/80 SS (or whatever).
If you do prefer a space saver (much less boot space robbed), you can run them front or rear, but you obviously have to take it easy while you tip-toe about.
If you're buying a 2nd hand SS, make sure you check the date code on the tyre. Lots of those SS are from E46 3 Series, and the 15 year old tyres are basically unreliable junk now.
Andykg
Re: space saver
Post by Andykg » Fri Sep 01, 2017 10:45 am
awesome, thanks for the quick reply.
Andykg
Re: space saver
Post by Andykg » Fri Sep 01, 2017 11:17 am
next question can i get any old full sized spare 16,17 or 18 that'll fit? or should i match my current wheels which are 208's?
Re: space saver
Post by marco_polo » Fri Sep 01, 2017 11:28 am
Any old BMW 16" should fit yours, in theory (unless you have upgraded brakes).
Andykg
Re: space saver
Post by Andykg » Fri Sep 01, 2017 11:50 am
thanks again
