Can I keep the size difference F/R with winter tyres?
M-140i
Post by M-140i » Tue Sep 19, 2017 7:54 am
On my xdrive?
I'm on 225/255 and I would like to keep this difference with my incoming winter setup.
_________________________ Image140ix__________________________
M-140i
Re: Can I keep the size difference F/R with winter tyres?
Post by M-140i » Tue Sep 19, 2017 7:58 am
I read somewhere in this forum that It wasn't advisable? :?
Post by marco_polo » Tue Sep 19, 2017 8:06 am
225/40/18 and 255/35/18 are a really good diameter match, so I think that would be the perfect set-up.
M-140i
Post by M-140i » Tue Sep 19, 2017 8:16 am
Thanks mate, someone (you ?) wrote in an other section of the forum that big rear winter wheels were not good and that 225 all round would be the better solution.
Post by marco_polo » Tue Sep 19, 2017 8:48 am
Link please, and I'll edit/delete that.
Technically, thinner are better in deep snow, but you shouldn't struggle in a 4x4. I would run 255 winter tyres on mine if they would fit on my wheels (as we don't get much deep snow).
sootyvrs
Post by sootyvrs » Tue Sep 19, 2017 9:10 am
In snow conditions a narrower tyre will give better traction and grip than a wide tyre...
If you follow rallying in snow you will see they are on the skinniest tyres in those conditions
2017 F21 BMW M140i Auto
2015 F56 Mini Cooper S Man
2013 F20 BMW M135i Auto
2010 R56 Mini Cooper D Man
2007 E87 BMW 130i Man
M-140i
Post by M-140i » Tue Sep 19, 2017 9:46 am
Here in Belgium, we have 2cm of snow every 10 years. :D
M-140i
Post by M-140i » Tue Sep 19, 2017 1:24 pm
posting.php?mode=quote&f=74&p=1325482
ZyBeR wrote:
Wed Sep 13, 2017 4:57 pm
Yeah I know there are multiple threads about this already, but I didn't find a good answer.
First of all, my car is a M135i -15 (LCI) Xdrive so I need fairly equally sized (circumference) fronts/reads.
My plan was to go with R:255/35-18 and F:225/40-18 but that seams impossible to find, as I live in Sweden I need special "Nordic compound" tires..
2nd options was pure stock size, same thing there, not available.
So what I have to choose between is:
1. Stock wheels with 225/40-18 front and 235/40-18 rear (narrower but taller).
2. X1 steel wheels with 225/45-17 all around.
Does anyone run the these setup and can comment on them?
marco_polo wrote:
Wed Sep 13, 2017 5:03 pm
On an xDrive, I'd fit a set-up with equal diameters.
Probably 225/40/18 all round, something like Nokian Hakkapeliitta R2
Post by marco_polo » Tue Sep 19, 2017 2:15 pm
I wouldn't recommend different diameter tyres for an xDrive, as that stresses the transfer box. Square are the same size obviously, as are 225/40 and 255/35. He is based in Scandinavia, so he's probably better on 225 rears.
I would not recommend 225/40 and 235/40 on an xDrive as they do not match. Does that clear things up?
M-140i
Post by M-140i » Tue Sep 19, 2017 6:37 pm
Yes MP. :)
2001.8mm circumference for 225
1997.1mm for 255
2027 mm for 235
