Tyre repairable ??
D6EML
Tyre repairable ??
Post by D6EML » Tue Apr 17, 2018 10:00 pm
Is this too close to the sidewall for a repair ?
Dean
M140i / SB / AUTO / 15mm HR / CARBON SPOILER / MAXTON KIT / AUTOID CAPS / M4 COMP REPS
Re: Tyre repairable ??
Post by Twenny » Tue Apr 17, 2018 10:12 pm
D6EML wrote:Is this too close to the sidewall for a repair ?
Dean
I’ve had closer repaired. Can’t find the damn photo though to show you. (Will keep looking)
D6EML
Post by D6EML » Tue Apr 17, 2018 10:53 pm
Dean
Ahh that’s good to hear twenny thanks.
Dean
Post by marco_polo » Tue Apr 17, 2018 11:13 pm
I wound have that repaired too.
D6EML
Post by D6EML » Tue Apr 17, 2018 11:21 pm
That’s reassuring , thanks guys
Post by Octavius » Tue Apr 17, 2018 11:29 pm
What’s the tread depth.
It’s repairable though.
D6EML
Post by D6EML » Wed Apr 18, 2018 7:52 am
Oh there’s plenty rubber on them , only done 8k
Billy1mate
Tyre repairable ??
Post by Billy1mate » Wed Apr 18, 2018 9:11 am
Yes, too close to the sidewall.
Barney McGrew
Post by Barney McGrew » Wed Apr 18, 2018 9:26 am
Looks a bit borderline.
The general 'rule of thumb' is it's only repairable when it's in the central 3/4 of the tyre. Outside of that is too close to the side wall.
You'd need to take it in to a repair place and see what they say. One might say no it's too close, others might be ok with it.
Blind Pugh
Post by Blind Pugh » Wed Apr 18, 2018 9:29 am
IIRC RoT is >1" from edge of a tyre then its repairable
AW M2 DCT
Barney McGrew
Post by Barney McGrew » Wed Apr 18, 2018 10:35 am
IIRC RoT is <1" from edge of a tyre then its repairable
If you could go <1" from the edge, a nail in only 0.5" from the edge would be ok, presume you mean >1" ;)
Blind Pugh
Post by Blind Pugh » Wed Apr 18, 2018 10:37 am
Yes - my bad you are correct - my post above edited accordingly.
AW M2 DCT
pem10
Post by pem10 » Thu Apr 19, 2018 9:05 pm
Pick up my fair share of those in my van and as said had nearer repaired. Just. Think the patch is about an inch in diameter and as long as that is on the flat part of the tyre ie not the side wall then your in luck. I'm sure all garages vary though.
Looks an expensive tyre and as is the way you'll probably want matching tread across the axle so hope you can get it repaired.
130i se. Sparkling graphite metallic. Xenons - darklines -pro hu - focal IFBMW-S -bmwp intake - roof spoiler. Now with added 313 goodness and other bits and bobs.
