The F20 Alloy Wheel Thread
Falltrack
Re: The F20 Alloy Wheel Thread
Post by Falltrack » Thu Jun 07, 2018 7:51 am
Alright great so if I go with the Wizards at 8x18 ET45 which tyre dimensions would you recommend?
And for the VMRs 8.5x18 ET40?
I'm not sure about the weights on the VMR V703s but they're probably around 22.5lbs/10.1kg which is what the V710s weigh. Either setup is lighter than stock anyway.
Post by marco_polo » Thu Jun 07, 2018 7:59 am
You can safely refit your stock tyres if you want, although the fronts will appear a little stretched.
I like to run 245/35 all round, but not MPSS as the 245/35/18 pattern doesn't clear standing water well.
Falltrack
Post by Falltrack » Thu Jun 07, 2018 8:29 am
Cheers, will go with 245/35 all around I think.
Unfortunately I have stock 17" 383M and almost new runflats on my 120d lci, got the car just a few weeks ago, the plan is to use winter tyres on those wheels and get rid of the runflats.
Ronburgundy1983
Post by Ronburgundy1983 » Sun Jun 17, 2018 10:35 pm
Team dynamics pro race 1.2
18"
8j
et40
* lowered on HR springs
Donz
Post by Donz » Tue Jul 03, 2018 12:20 am
Ok as ever I’m looking for confirmation!
I’m considering18x 8.5” all round et35 with a square tyre set up 235/40/18 - cup 2’s for track days. Too pokey?!
Clio 172 mk2, Impreza blob prodrive,Impreza hawkeye cosworth, 325d Touring, M140i and a ph1 172
Post by marco_polo » Tue Jul 03, 2018 6:58 am
235mm at ET35 shouldn't rub, assuming you're on stock wishbones?
Donz
Post by Donz » Tue Jul 03, 2018 8:08 am
All stock. I was using 15mm spacers anyway so minus them there is only a slight difference!! 235 on 8.5 shouldn’t appear ‘stretched’ should they?
Thanks again
Post by marco_polo » Tue Jul 03, 2018 8:15 am
235 on 8.5j will look slightly stretched. Perfectly safe, but next to zero rim protection so watch those kerbstones.
