The F20 Alloy Wheel Thread
Re: The F20 Alloy Wheel Thread
Post by marco_polo » Wed Mar 28, 2018 9:43 pm
255mm at ET35 isn't going to fit at all.
bmwf2x
Post by bmwf2x » Wed Mar 28, 2018 10:20 pm
F20 2013
405M Replica, 8J ET40 18"
225/40/18 allround.ImageImageImageImage
ZyBeR
Post by ZyBeR » Sun Apr 01, 2018 8:45 am
Is it possible to run 18x8.5 with 255/35 or 245/40 on a M135i Xdrive (LCI) lowered with KW V1?
I know it won’t be any issues in the rear, but up front it will be tight, especially without camberplates, question is if it will work with the correct ET?
For the rears should I aim for et45? How about the fronts, 40, 41 something?
Goon
Post by Goon » Mon Apr 02, 2018 8:50 am
Nugs wrote:
Thu Jan 18, 2018 6:02 am
PIcked up some new forged Japanese goodness.
Advan GTs with AD08r tyres.
Specs are
front: 18x8.5et35 with 225/40/18
rear: 18x9 et52 with 255/35/18
Fitment is spot on!
Looks good, I really like those, tidy offset match for rears too, where did you get them from.
Nugs
Post by Nugs » Tue Apr 03, 2018 5:54 am
Specs are
Fitment is spot on!
Thanks mate.
I am in Australia so not sure how much help this is but I just got them from a local tyre place that imports/distributes Advan products.
ZyBeR
Post by ZyBeR » Tue Apr 03, 2018 9:18 pm
Specs are
Fitment is spot on!
I'm looking to fet the same size for tyres, also r-compound.
But I can't find any wheels with high ET.
How do you think it would work wit h18x9 ET45 in the rear and 18x8 ET38 in the front?
(same tyres as you have now)
Nugs
Post by Nugs » Fri Apr 06, 2018 7:10 am
Specs are
Fitment is spot on!
Looks like it would be touch and go in the rear. I just went and measured and it looks like I would have 5mm clearance between the guard and the sidewall at full compression, I’m running -2 camber.
And the wheels you are looking at stick out 7mm further than mine.
SimonB5
Post by SimonB5 » Sat Apr 14, 2018 9:23 pm
TECSpeed GT6 8x18 ET35 running stock sizes MPSS..
Mineral Grey M140 - Auto - M Performance Exhaust
crp207
Post by crp207 » Sat Apr 14, 2018 10:52 pm
Apex ARC8 Fr; 18x8.5J et45 Rr: 18x9.5J et58, fronts have a 3mm spacer with stock tyre size (will go to a 245 tyre when they die) rears have a 255/35 tyre
M140i-sapphire black-apex ARC-8's-jb4-scorpion exhaust-M3 LCA-430 bhp tyre slayer
toncho83
Post by toncho83 » Tue Apr 24, 2018 12:29 pm
Hello guys,
I already bought "Borbet CW 2 black" second hand.
front : 19 inch, et35, 8 j with 235/35/19 very good Michelin tires
rear : 19 inch, et35, 9 j what tires i need to buy? 245/30/19 ? Should i need spacers as well, because of the positive scrub radius?
Post by marco_polo » Tue Apr 24, 2018 12:36 pm
You definitely don't need spacers!! Spacers would make everything worse.
245mm rears might rub. I'd put one of your 235/35's on a back rim and check the fitment.
225/35/19 might be a better fit on the front?
M-140i
Post by M-140i » Tue Apr 24, 2018 6:21 pm
Hello guys,
On a 1 serie, 9x19 ET35 will definitively not be ok.
The only way, imo, to avoid some problems is to go with 235x35 but in this case, the rim will not be protected in case of contact with sidewalks.
If you have a 2 serie, I don't know.
_________________________ Image140ix__________________________
toncho83
Post by toncho83 » Wed Apr 25, 2018 6:56 am
Тhank u guys.I will put 235/35 on rear first to check fitment.
Duncan.B
Post by Duncan.B » Fri May 04, 2018 3:28 pm
how do you find the clearance at the rear ? do yo have any spacers fitted to bring it out from the spring ?
current have 9.5j et 45 rears and wondering how much space you have on the inside ?
Current- Valencia Orange M135i- MHD 2+, BMS Intercooler, Forge Chargepipe, Decat, H&R springs 25mm , 19” 763m Reps.
Past: M235i-JB4, Decat, Cobra Cat Back, OZ Formula HLT 437Hp / 472 Ft.Lb
crp207
Post by crp207 » Mon May 07, 2018 4:55 pm
Rear clearance is close but no need for a spacer
