Hall of Fame: Aftermarket Wheels and/or tyres examples
mashie1994
Re: Hall of Fame: Aftermarket Wheels and/or tyres examples
Post by mashie1994 » Tue Nov 14, 2017 7:49 pm
Can't be a 135 with comp wheels!
cameronmurray3
Post by cameronmurray3 » Tue Feb 06, 2018 2:42 am
I’m running 225m (mv4) Wheels I’m my 120d coupe. 8j et37 225/35r19 all round. No rubbing that’s worth mentioning!
Current: Sapphire black E82 120D poverty spec. Stage 1 (228bhp) bilstein b12+eibach pro kit 225/35R19 tyres
Previous: 2003 BMW 318ci SE
G1NGE
Post by G1NGE » Wed Feb 07, 2018 10:40 am
Michmash/eddie wrote:
Sat Mar 25, 2017 10:23 am
Just ordered from bm auto sport, RIVA DTM CSL style wheels.
18x8 ET 34 with 225 40 18 tyres
18x8.5 ET 37 with 245 35 18 tyres
They fit the arches perfectly, very happy with them.
A big thanks to Mark & Carrie, fantastic customer services and they put up with all my emails and constant questions.
Hi - wheels look really good. With the offset of 34 on the front and the rim being an 8, how does the wheel and tyre look regarding the stance? Does it protrude much when looking side on or straight down from above? Some opinions are that an offset of 35 is border line regarding how much the wheel and tyre sticks out. From the images, it looks spot on but it is hard to tell properly.
PazzaAE86
Post by PazzaAE86 » Mon Mar 05, 2018 8:17 am
E90 320si BBS 216s.. Fit great, a little shy up front but a small spacer would work great.
F21 M135i - Silver - ZF 8 speed - HSD Coilovers - MPE - BBS Style 216 wheels
Fritz
Post by Fritz » Mon Mar 05, 2018 11:24 am
Are these different to the ones supplied on the 130i LE? Would you happen to know the weight?
PazzaAE86
Post by PazzaAE86 » Mon Mar 05, 2018 6:50 pm
Lower offset and half an inch wider I believe.. They arent the lightest, probably similar stock M135i alloys.
Manc M135i
Post by Manc M135i » Thu Mar 08, 2018 8:41 pm
Would these fit an M140i running F235 / R255 width tyres?
https://rover.ebay.com/rover/0/0/0?mpre ... 2965051692
Kubricks
Post by Kubricks » Fri Mar 16, 2018 1:06 am
Just fitted 255/35/18 on a 18" 8.5" ET44 wheel on front axle, with camber plate running 3.0 degree camber.
It clears with no fender mod, the wheel has 3mm clearance to the strut while the tyre has 2mm, I will put in a 3mm spacer later just for safety.
130i M Sport manual | ESS Supercharged | Custom remap
Birds B1 Suspension set | Vorshlag camber plate | Quaife Limited slip differential | M3 Chassis parts
18" Pro-drive GC-014i wheels
ZyBeR
Post by ZyBeR » Sun Apr 01, 2018 8:47 am
Kubricks wrote:Just fitted 255/35/18 on a 18" 8.5" ET44 wheel on front axle, with camber plate running 3.0 degree camber.
Would this have been possible without the camber plates? I’m looking to run the same setup on my M135i Xdrive (LCI), I don’t have camber plates but it’s sitting Low on a set of KW V1.
Kubricks
Post by Kubricks » Tue Apr 10, 2018 2:32 am
Well.... M135i is a different car I am not sure clearance data is comparable? :oops:
On the E87 I guess no, you must have full 3 degree camber to clear the fender, I am barely clearing it.
shrjun
Post by shrjun » Fri Apr 20, 2018 6:02 am
2014 F20 116i Msport , 18 " BBS CHR brilliant silver
2014 F20 116i M sport manual HK audio 18" BBS CH-R
steve1477
Post by steve1477 » Wed Apr 25, 2018 9:10 am
WSP Italy Basel M, Front 7.5 x 18 et 47 225/40/18 Avon zz5s, Rear 8.5 x 18 et 52 255/35/18 Avon zz5s.
